i bought this excellent gaming computer(Gateway FX6000 series) yesterday, installed ArmA Gold on it... the game works fine on my Toshiba laptop, after installing it i let it run. In the main menu, the screen is black for the top half and the bottom is white and where the icons are supposed to be there's black squares... i can click on them and go to other menus but they are all appearing the same, Ive tried changing the in game graphics but did nothing... i noticed that Vista is not one of the supported operating systems but my laptop which is also vista and that works ok, other then having to run the graphics at minimum, if you have any idea of how i can solve this problem that would be greatly appreciated, thank you
well that im not too sure, but i got this desktop at future shop here are the specs...
Processor Type Intel Core i7 920
Processor Speed 2.66GHz
RAM 9GB DDR3
Hard Drive Speed/Capacity 1TB SATA 7200RPM
Optical Drives 18X DVD+/-R/RW with Labelflash
Graphics ATI Radeon HD4870
Pre-loaded Operating System Windows Vista Home Premium 64-Bit
Graphics Dedicated Video Memory Yes
Shared Video Memory No
TV Tuner No
Video Memory 1GB
Display N/A
HDCP Compliant No
Native Screen Resolution No
Screen Size/Type No
Audio
Audio Output 8-Channel 7.1 High Definition Audio
