I just ordered parts for a new computer from Newegg, And I am wondering if the Power Supply I ordered will be enough power for the components below.
Power Supply: Rosewill RP550V2-D-SL 550W ATX12V v2.01 SLI Ready CrossFire Ready. http://www.newegg.com/Product/Product.aspx?Item=N82E16817182030
CPU: Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775
GFXCard: EVGA 896-P3-1260-AR GeForce GTX 260 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP
Mobo: GIGABYTE GA-EP45-UD3R LGA 775 Intel P45 ATX Intel Motherboard
HD: Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s
Memory: G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500)
DVDDrive: LG 22X DVD±R DVD Burner Black SATA Model GH22NS30
This will all be going in an Antec 900 case.
So will the PSU I ordered supply enough power? I read a review that the PSU would power the GTX 260 and Q6600. But nobody had both components together with this PSU.
Another thing is I did not order a CPU Cooler because I do not plan on OCing. Will my temps be ok without an aftermarket CPU Cooler with those components?
Any other feedback would be very much appreciated.
