Check to make sure it's not muted? When you say you got all the hardware, do you mean you checked to make sure it's working with no errors and the drivers are installed? Try external speakers or headphones also to make sure your internal speaker connection is not bad. Is the audio device seen in the Control Panel? Set as the default playback device?
