Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Help, what gfx card for playing on 40 inch 1080p Samsung
Forum Graphic & Displays : Graphics Cards - Help, what gfx card for playing on 40 inch 1080p Samsung
Heya all,
I really need help with my next gfx card decision. Atm my system specs are:
Q6600 @ 3.2ghx
8800gtx
IP35 pro mobo
750w psu
4gb ram
40 inch samsung 1080p
The games i intend playing at the highest resolution and some aa/af (if possible) are:
crysis warhead
crysis
GTA IV
Left 4 dead
Grid
UT3
Money is not really a big issue, tho i want something that is not gonna be too over the top for my needs :)
All input appreciated
Thanks
Sponsored Links
minimum 260GTX 216 or HD4870 1GB.
Reply to rolli59
Most likely a drop in 4870 1 GB, or if you can spare the cash a 4890 will work.
I like this version of the 4890 because of the double lifetime warranty:
http://www.newegg.com/Product/Prod [...] 6814150359
------------------------------ Core 2 Duo E8400 @ 3.6GHz (stock voltage) - Xigmatek HDT-S1283 Cooler - OCZ Reaper X DDR2 800 (4X2 gigs) - GIGABYTE GA-EP45-DS3L - Sapphire Radeon 4850 - VelociRaptor 1500HLFS - WD 640AAKS - Samsung 2433BW - Sony Bravia 40" 1080P
Reply to Oakley707
Yeah HD4870 1GB or 260GTX should do well, although if you want to max game quality on Crysis you mihgt need to run it at 720p instead at 1080p.... but dont feel bad, I think they did a poor optimization in Crysis, thus the new redesign of their Cryengine
I just got a second hd4870 1gb myself. I play at 1080p and everything maxed.
I love it.
Reply to Euphoria_MK
A 4870 1gig would be great. But if you want to max crysis you will need a crossfire configuration of 4890's since you cant SLI with that MB.
It is not adviced to build a computer around crysis since its requirements for max settings are SOOO much higher than any other game out there.
------------------------------ CPU: Q9550 at 3.6ghz (FSB 425mhz) | MB: P5E3 Premium | Ram: 4*2Gb Corsair DDR3 @1417mhz | GPU: 2 HD4890 1Gb (925core/1025mem) CF | PSU: OCZ ELiteXtreme 800W | Sound: Creative Titanium Fatal1ty Pro | 2*120gb OCZ Vertex SSD Raid0 and 2 500gb Raid0 HDDS
Reply to daedalus685
Thanks guys for the replies, is the 4870 quite an upgrade from an 8800gtx?
Reply to brutus3095
This should give you an example of the upgrade.
http://www.nvnews.net/vbulletin/sh [...] p?t=115791
Reply to Oakley707
Yes it is an improvement if you are playing at high resolutions.
Pleas note that the link comparison provided by Oakley707 is a year old and is way before Cat 9.x drivers were out. Performance and stability of HD4870 through drivers has increased since than. Plus these benchies were done with AA at 0. Once you enable AA at high resolutions 8800GTX gets a really big hit in Frames per Sec. making it unusable for some games....
Cheers
^+1.
8.6-9.4 drivers have made vast improvements.
Reply to Oakley707
You shouldn't have a problem with the 8800, why do you need to upgrade?
Reply to W0lfZ3ro
Quote :
not on my 4870.
Message quoted 1 times
Message edited by wh3resmycar on 04-28-2009 at 05:47:15 AM
Reply to wh3resmycar
I'd think about a Nvidia GTX 275 since you mentioned crysis.
Don't plan on maxing out GTA, but it will still look good. . .
Reply to San Pedro
wh3resmycar wrote :
not on my 4870.
To bad. I use Cat 9.4 for two HD4870 1GB in Crossfire and they work like a charm.
Both are oced at 790/1000 and not even a glitch.
Cheers
There are 904 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
