I just have two quick questions to ask..
system :
Ati 4870
Phenom II 1055T @ 3.64Ghz
3Gb 2x1gb 2x512gbmb 866mhz
Asus m4a78 Pro am2+
When i don't use my CPU it clocks down to 1040 mhz the multiplier goes from 14x to 4x when the cpu is not getting used.. I have turned of the "Cool n Quiet" what can that be?
I also have a temp question i just tested with Prime95 and after 2 hours running 100% the cpu temp had maxed with 36c can, i checked with all different programs like Coretemp. speedfan. everest. hwmonitor and they all showed the same temp is it posible that they show un-accurate?
system :
Ati 4870
Asus m4a78 Pro am2+
