Tom's Hardware > Forum > Motherboards & Memory > Asus > System freeze after hours of heavy load
Forum Motherboards & Memory : Asus - System freeze after hours of heavy load
Hi All,
I would like to get some help, how to approach, how to find and localize my problem, which is the following :
I use MATLAB for heavy numerical computations, which really use all 4 cores (AMD Phenom ii x4) in 100 % continously, and deals with large amounts of data (matrices of 1-4 Gb).
The system freezes after a few hours (typically 1-4 hours) of this kind of load.
It doesn't seem to be software dependent, as I have windows and linux also installed on the same machine, both running the same code, and both freeze (altough not always after the same amount of time)
I logged the temperatures using everest, and they never exceed 50-52 C for the cores, and 37 C for the chipset.
setup:
AMD Phenom ii x4 945
ASUS M4A78-EM
8 Gb Corsair XMS2 6400 (5-5-5-18, 1.8V) memory in 4x2 Gb
LG DVD burner
Samsung F1 500 Gb HDD
OCZ ModXStream Pro PSU 500W.
ArcticCooling Freezer 64 Pro PWM CPU cooler
Nothing is overclocked.
Before installing the system, I ran memtest86+ for the RAM, and found no problem.
What I have additionaly tested by now, is that I ran the system stability test in Everest Ultimate Edition, stressing the CPU, FPU, cache, memory countinously. Voltages, and temperatures seemed to be rock stable, and the test had been running already for 15 hours when I stopped it.
hints, how to go on ? what to check ?
thx
Sponsored Links
I'd try removing half your memory and and seeing if you still have a problem. If you do, then swap with the other half of the memory to see if that fixes the problem.
Reply to sminlal
- 0 +
I have tried it, but the problem doesnt seem to appear consistently.
I found a new code sample, which sometimes immediatley freezes the machine,
sometimes it can run continously for hours.
A few times, when the freeze occured, there were some weird patterns mixed with the original display.
As I use the IGP on my board, I dont know if it couldnt be an issue with shared memory, or whatever.
Reply to Fenton
Try raising the ram to 1.9V or even 2.0V. When using 4 sticks of ram, you may need a little extra voltage. However, are you sure that it's not just the Matlab code itself causing the the freeze? Can you run it on a different computer without issues?
Reply to orangegator
- 0 +
Yes, sure, the code runs without problems on other computers.
OK, I can try the trick with the ram voltage.
I also heard about the increase of VDDNB ... but I don't know what is it exatly, and what influence it has.
Reply to Fenton
There are 886 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
