Tom's Hardware > Forum > Graphic & Displays > ATI > Radeon 4850 Help
Radeon 4850 Help
Forum Graphic & Displays : ATI - Radeon 4850 Help
I just upgraded to a visiontek 4850 from an nvidia 7650gt
The card works fairly well but its lags out bad at times. I have the defaults on and have even turned off all the antialiasing and whatnot. But still when i try to play combat arms it works fine at times but during lots of gunfire it starts to lag out pretty bad.
Before you ask yes i did uninstall the nvidia drivers and i have the newest CCC downloaded and installed
Can someone help?
Its running with an Amd 64 5000+, 4 gigs of ram, running windows xp, and not sure on resolution at the moment its on a small hand me down lcd (which never gave issues before hand)
Message edited by thrule01 on 05-09-2009 at 12:06:38 AM
Sponsored Links
I have the same problem. It doesn't exactly lag, but well, for a fraction of a second the game freezes, then resume smoothly. This happens quite frequently in Mirror's Edge - perhaps due to PhysX even though its disabled? But it seems to be fine in others. And do you have XP 32 or 64?
------------------------------ Intel Core 2 Quad Q6600 @ 2.4 | Thermalright Ultima 90 120mm fan | Intel DG31PR | 4 GB DDR2 @ 800MHz | HD 4850 512 GDDR3 | Corsair VX450 | Samsung 22x DVD RW | Windows Vista HP 32-bit/ Windows 7 64-bit dual boot | Samsung SyncMaster 19" LCD VGA 920NW |
Reply to rags_20
xp 32 bit...
and yes thats what it is..and like when i do fire it seems like everything is in slow mode even tho its happening faster...and i only have it set to medium graphics in the game...
Reply to thrule01
well, I guess that's ATI drivers. They work properly with some systems, not so with some. Wish I'd stuck with nvidia.
Reply to rags_20
well we use them with similar cpus at the office and have no problem with them...but they are used for autocad and such here and not for gaming...
Reply to thrule01
anyone else have any help/advise?
Reply to thrule01
What PSU are you using? Perhaps the new card is simply trying to draw more power than it can provide (please list name, output and output on the +12v side).
Sometimes this is because of driver conflicts. The problem is that neither Nvidia nor ATI seem to know how to make a thorough uninstaller and components often get left behind by it, causing problems.
Try this: Download the latest drivers. Download and install Driver Sweeper. Set a Restore Point (importaint). Uninstall your current drivers and restart in Safe Mode (hold F8 while it is booting). Run Driver Sweeper and clear out any existing ATI and Nvidia components but be careful , it can remove vital Registry entries so examine every item before removal. Restart and install the drivers as nomal. This may or may not cure the problem but it will remove the most common driver related issues.
One other thing I have found helpful is to turn off or reduce the quality of shadows.
Reply to coozie7
its a rosewill...i will have to get model # when i get home....i know its not the best PSU so ive been told....
and i may have to try that...i guess ill have to enable system restore...i usually always have it disabled...
any other ideas as well?
Message edited by thrule01 on 04-28-2009 at 11:37:49 PM
Reply to thrule01
well tried that driver sweeper and now when i reinstall CCC it wont load cause a file is missing from registry and so on..
talked to a few of my gamer friends and they said "reformat..." a few of them have had this issue as well...
Reply to thrule01
Sorry to hear you are having yet more problems.
If System Restore will not do the trick you could always use the 'Repair' install rather than a full format and reinstall, you will still need to update Windows and probably reinstall the games but your data files data will remain intact.
Reply to coozie7
hrm..may have to try that..i was tempted to just pull the HD and use a backup one for now and just copy all my stuff over after fresh install...
Reply to thrule01
With the way things are going at the moment, I'd backup to the other drive first if you can, Murphys Law seems to like you:(
Message edited by coozie7 on 04-29-2009 at 09:17:22 PM
Reply to coozie7
im just gonna pull the drive and slap in a new one and slave the other one on a usb adapter to transfer all my files over so i just have to back everything up once...
Reply to thrule01
Sensible.
Shame it's gone bad for you.
Wish you luck.
Reply to coozie7
its all good...she was due for a fresh install anyways...i just have been procrastinating..will let yall know if problem is fixed after format...
wont be for a few days most likely due to work and whatnot
Reply to thrule01
I shall wait with baited breath (mild sarcasm) :)
Reply to coozie7
A fresh install *should* cure your woes. Update us once it's done.
Reply to mtyermom
had a fresh install going and all was fine...once windows loaded for the first time after the install i clicked on start and bam the screen goes black...
now i have no idea and when i reboot i dont hear the bios beep/post and no video still...any ideas?
btw my psu is a rosewill rp500-2
http://www.newegg.com/Product/Prod [...] 6817182016
Message edited by thrule01 on 05-06-2009 at 06:23:09 PM
Reply to thrule01
i was thinking its the mobo/cpu...but im told its the mobo...
Reply to thrule01
did u check your bios settings? u may also want to partition your hard drive so that the next time u need to re-install only the windows files go and all else stays
partition through the windows install or get a program like partition magic
no beep on boot usually means your memory is not seated right, you may want to check all your hardware and connections..........also a program to test it called prime95
Reply to fire77
There are 836 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
