Tom's Hardware > Forum > CPU & Components > Other Components > Will this cooling sytem work with i7?
Forum CPU & Components : Other Components - Will this cooling sytem work with i7?
I'm trying to find a good water cooling system and I need to know if one of these will work with an i7 socket. And if it doesn't, can I buy a kit for it.
http://www.circuitcity.com/applica [...] CatId=1057
or
Sponsored Links
http://www.scan.co.uk/Products/Cor [...] CPU-Cooler
Try the corsair h50 my friend has the i7 920 running @ 4ghz n he gets about 35-40 degrees idle n 55-60 on full load hope this helps
Reply to mrnathan92
There are 1346 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
