Water Cooling Help
Forum CPU & Components : Other Components - Water Cooling Help
Hello all,
I have been doing some reading and have some questions based on my homework, I recently upgraded my entire pc, I have an Antech 1200 case, I am not happy with my temps currently with air cooling so I have started investigating liquid cooling.
This is my first time for water cooling, and I am trying to be prepared before the parts arrive, I also am finding it difficult to order all the parts connectors clamps etc, and secondarily visualize or draw out the flow of water through the system, which I believe has to be a dual loop configuration bc i have dual gpu's that draw 298 watts a piece lots of heat! here are my specs to start off.
OS
Windows Vistaâ„¢ Home Premium 64 BIT
Graphics
Dual BFG Tech BFGEGTX2951792E GeForce GTX 295 1792MB 896 (448 x 2)-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI
http://www.newegg.com/Product/Prod [...] 6814143167
Monitor
ASUS 24 Inch VW246H using a DVI connection. 2 ms refresh
Processor
Intel Core i7 Extreme Edition 965 Nehalem 3.2GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor
OverClocked to to 3.8 GHZ
http://www.newegg.com/Product/Prod [...] 6819115200
PSU
ABS Tagan BZ Series BZ1300 1300W ATX12V / EPS12V SLI Ready CrossFire Ready Modular Active PFC Patent Piperock Modular Power Supply
http://www.newegg.com/Product/Prod [...] 6817814011
Case
Antec Twelve Hundred Black Steel ATX Full Tower Computer Case - Retail
http://www.newegg.com/Product/Prod [...] 6811129043
Mother Board
EVGA E758-TR 3-Way SLI (x16/x16/x8) LGA 1366 Intel X58 ATX Intel Motherboard
http://www.newegg.com/Product/Prod [...] 6813188046
My mother board manual is here http://www.evga.com/support/manual [...] L-E758.pdf
So basically I have read up on the system components I think I need, I will be cooling the following components Dual GTX 295's in SLI they are in slots 1 and 2 of my mother board which are right on top of each other, this is because those two slots operate at 16x or 8GBS, the pci express slot at the bottom of the mother board is a x8 slot. I will also be cooling the north and south bridges and the cpu, I am most concerned with having my video cards being the coolest I use the dummy oc feature in the evga mobo but nothing more for cpu overclocking yet! :-)
I have looked up the following components and connectors, hoses etc for the system, can someone please take a look and tell me if I am on target missing anything, or any advice?
For my cable width I used http://www.primelineindustries.com/pdfs/sizechart.pdf
I believe I will be running 1/4 off the back of the cooling unit it will be 3/8 inside the case, then 1/4 inch to the water blocks then converted back to 3/8 although for the cooling unit I was a bit confused it says it has 1/4 entering and exiting but then it says it supports 3/8 inch
This is form the web site for the Koolance Exos-2.5
Quote :
"The Exos-2.5 features rear G 1/4 threaded inlet and outlet nozzle sockets (nozzles are not included). This allows any Koolance G 1/4 nozzle or threaded quick-disconnect to be added to the unit. Like all Exos systems, the Exos-2.5 will connect with any PC through a standard rear card slot. This is ideal to avoid any modification to the computer chassis.
NOTE: The included Exos Slot Adapter will accommodate tubing up to 3/8" (10mm) ID, 1/2" (13mm) OD. If using 1/2" (13mm) ID tubing, Koolance recommends the BKT-PCI-G with your preferred nozzles."
I have used the following guides to help me come to this point
http://www.tomshardware.com/review [...] ,1573.html
Installing the Koolance VID-NX295 GPU waterblock
http://www.youtube.com/watch?v=WALEIXbzkXU
Review of the VID-NX295 GPU Waterblock
http://www.youtube.com/watch?v=HqyUoFn6ZkY
Here is the is the list of equipment I have compiled.
External Cooling System
http://www.koolance.com/water-cool [...] uct_id=668
Liquid Coolant Bottle, High-Performance, 700mL (Fluorescent Blue)
Nozzle Pair, G 1/4" Barb [For ID: 10mm (3/8" )]
3 Feet of Tubing, Clear UV-Reactive PVC, 1ft/30.5cm [ID: 10mm (3/8" ); OD: 13mm (1/2" )]
3 Feet of Tubing, Clear UV-Reactive PVC, 1ft/30.5cm [ID: 06mm (1/4" ); OD: 10mm (3/8" )]
Gpu Water Block x2
http://www.koolance.com/water-cool [...] uct_id=778
CPU Water Block
http://www.koolance.com/water-cool [...] uct_id=753
North Bridge Water Block
http://www.koolance.com/water-cool [...] uct_id=662
South Bridge Water Block
http://www.koolance.com/water-cool [...] uct_id=663
Fittings
http://www.koolance.com/water-cool [...] uct_id=137
Tubing Splitter, F 10-6mm (Plastic)
http://www.koolance.com/water-cool [...] duct_id=47
Hose Clamp [For OD: 10mm (3/8" )]
Any feedback would be greatly appreciated,
Sincerely,
Justin
Sponsored Links
Errrr... do you really need two GTX 295s? You're "only" using a 24" monitor, and a dual-295 setup is designed to drive two 30" monitors at the very least. Try taking out one; I guarantee your heat problem will be reduced significantly.
------------------------------ Desktop | E7300 | P5KPL-AM | 2GB DDR2 667MHz | NVIDIA 9500 GT | ST3320613AS | w2228h
XPS M1330 | T8300 | Dell 0U8042 | 2GB DDR2 800MHz | NVIDIA 8400M GS | WD2500BEVS-75US | 1280 x 800
Reply to r_manic
Tom's Hardware > Forum > CPU & Components > Other Components > Water Cooling Help
There are 622 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
