Ok so i have a 1000 dollars to spend and i have built a AMD Rig that should hold up pretty well.
https://secure.newegg.com/WishList/MySavedWishDetail.aspx?ID=15221967
The 1000 is purely for the tower not the monitor.
For a power supply i have a http://www.newegg.com/Product/Product.aspx?Item=N82E16817341002 so i should be ok with the 4890.
Any comments are welcome!
