I've been attempting to install the Freezer 7 for a couple hours now and I'm getting quite frustrated so I figured I oughta ask for some advice.
I took off the bracket on the mobo that the hsf connects to and connected them together out of the case and then I put it in the case but the screws for the bracket aren't long enough to screw back in with the hsf attached. I've read to just apply pressure and screw it in but it seems as if I have to apply enough pressure so that the entire hsf tilts backwards and makes the other end of the bracket too far away from the mobo to screw it in.
And I'm using an AM3 processor and of course, the AM3 parts of the heatsink.
Thanks in advance for any help.
