Archived from groups: microsoft.public.windowsxp.configuration_manage (
More info?)
Yes, that's what I'd do . . .
Good Luck !
>-----Original Message-----
>I've been to both the sites shown below...
>1. Only incomplete entry in the "run" section is for
Symantec's
>CleanSweep. Then item is listed as "QD FastAndSafe" with
nothing listed in
>the values section. Not sure just what it's needed for /
could not find any
>reference to the entry in Symantec's knowledge base. I
assume I could
>delete the key/value and see if the problem goes away.
That's the only
>incomplete/ empty listing. There are none with ""
entries on the right
>side.
>2. The kellys-korner entry is an option (looked at
this previously), but
>I was hesitant to use it as my problem doesn't fit the
conditions for which
>the fix was listed. I don't have to go into IE (and
don't get a blank
>window when I do) and then reboot to have the problem
occur.
>It all seems to hinge on the one entry, e.g., /L:Eng
and a reference to
>the two instances where the "run" key is found in the
registry. If I
>activate the entry, the problem occurs. If I uncheck the
box, the problem
>goes away. I thought, same as you, that it referred to
an English selection
>for a program. However, I don't find any parms listed
anywhere that
>indicate that or any incomplete entries where it
might "fit."
>Should I go ahead and remove the QD FastAndSafe entry to
see if it goes
>away? I assume I could always reenter it as a new key if
it's needed.
>Thanks!
>"MGGP" <anonymous@discussions.microsoft.com> wrote in
message
>news:12ece01c4436f$a60060d0$a401280a@phx.gbl...
>> Look here:
http://support.microsoft.com/default.aspx?scid=170086
>> and here but be sure to read the top part FIRST:
>> Line 260 - right hand side
http://www.kellys-korner-xp.com/xp_tweaks.htm
>> It sounds like an invalid entry, part of something that
>> was removed but not completely, thus the /L:Eng which
>> probably designates English as the particular "flavor"
of
>> the original (now screwed up) program entry.
>> Good Luck !
>> >Have a listing in my msconfig as follows:
>> >/L:Eng
>> >When this is checked to run at startup Windows XP opens
>> WinExplorer and
>> >defaults to the System 32 folder on the desktop. The
>> reference in MSCONFIG
>> >is to "Software/Microsoft/Windows/CurrentVersion/Run"
in
>> Regedit. However,
>> >I find no reference to this tag in either of the
>> locations for
>> >"currentversion/run" in Regedit.
>> >If I uncheck the box and reboot I'm fine. I would
like,
>> however, to find
>> >the basis for the line and, if not needed, remove it's
>> reference from
>> >regedit so it doesn't load in the future.
>> >A search of regedit doesn't find any text matching the
>> entry.
>> >Thanks!
