Tom's Hardware > Forum > Graphic & Displays > ATI > Graphics card problem please help
Forum Graphic & Displays : ATI - Graphics card problem please help
Hi just installed this card, cant get it to work through hdtv, I'm afraid am a bit of a spoon when it comes to this stuff.
Card installed, drivers installed , Catylist control centre installed, card recognizes hdtv hooked up no picture or audio though.
I have hooked up with DVI from card to hdmi on tv with a cable I bought but it may be the wrong kind DVI-D(Single link ) I think.
looks like this :
000 000
== 000 000
000 000
is this the right type.
Just get a blue screen on tv when going through all hdmi connections.
This was the only reason I got the card to use tv as a monitor or watch hd clips.
Does anyone know which type of dvi/hdmi cable is required??
And is the card meant to come with one supplied as I've not recieved this.
Card came with 1 xDriver CD
1 X Support manual CD
1 x DVi to VGA Adapter
1 x S Video Cable
Is This Correct
Any ideas
Sponsored Links
Please tell us what card you have installed... no info on card = no info on your problem...
Also the specs on your computer may help too.
Reply to themanstan
Hi thanks for the reply problem solved though bought ASUS EAH3450 but apparently there are two models one with native hdmi connection and one without, just RMA'd it with ebuyer, but there details on the card were a little misleading- anyway card performs now as I dont play games or anything just wanting to watch some hi def stuff, cheers
Reply to rojo37
Reply to rojo37
There are 1068 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
