Hello!
I have recently bought myself a set of a DL dvd to burn some stuff off my hard drive. My very old LG dvd-writer didn't want to burn them and right after the start of the burning process the error was showing up. So I took the dvd to my brothers PC and try my luck there. It worked, so now I was sure that it is a problem with my drive (wasn't very surprised as the writers was on run for a good few years). I bought a new writer the LG GH22LS50. Happy that finally I will be able to use my DL dvd I tried it out today. First DVD didn't go right. The error came up at 100% saying it couldn't end-up a Disc-one session. I then download and install the newest driver for it and it worked! But not for long. The data that I tied to burn and it worked was a disc image. When I'm now trying to burn some movies it simply crashes at random points of the process . No matter what data I'm trying to burn (yes, I'm sure the files aren't corrupted). What is the weirdest thing in it is that I manage to burn 1 disc with movies on it but then when I tried next and next.. and then next the error was showing up and I had to bin a dvd . It's a brand new drive so I don't think that that is a problem.
The error that I'm getting is as follows (ps. It's a Windows 7 ):
Windows Vista 6.1
AMD64
Wow64Process
WinAspi: -
NT-SPTI used
Nero Version: 9.4.13.100
Internal Version: 9, 4, 13, 100
(Nero Express)
Recorder: <HL-DT-ST DVDRAM GH22LS50>Version: TL03 - HA 1 TA 4 - 9.4.13.100
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data
CD-ROM: <PQNEL 3CHM745UR45E >Version: 1.03 - HA 1 TA 2 - 9.4.13.100
=== Scsi-Device-Map ===
CdRomPeripheral : PQNEL 3CHM745UR45E 1.03 alqydy6q Port 4 ID 0 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST CD-RW GCE-8481B H: CdRom0
PQNEL 3CHM745UR45E L: CdRom2
HL-DT-ST DVDRAM GH22LS50 D: CdRom4
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 4094MB (4192824kB)
Free physical memory: 1886MB (1931396kB)
Memory in use : 53 %
Uncached PFiles: 0x0
Global Bus Type: default (0)
Check supported media : Disabled (0)
11.11.2010
UDF compilation
22:03:28 #1 Text 0 File SCSIPTICommands.cpp, Line 430
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
22:03:28 #2 Text 0 File Isodoc.cpp, Line 6998
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : pure
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
22:03:28 #3 Text 0 File Burncd.cpp, Line 3572
Turn on Disc-At-Once, using DVD media
22:03:28 #4 Text 0 File DlgWaitCD.cpp, Line 313
Last possible write address on media: 4173823
Last address to be written: 3691999
22:03:28 #5 Text 0 File DlgWaitCD.cpp, Line 325
Write in overburning mode: NO (enabled: CD)
22:03:28 #6 Text 0 File DlgWaitCD.cpp, Line 2843
Recorder: HL-DT-ST DVDRAM GH22LS50, Media type: DVD+R DL
Disc Manufacturer ID: <RICOHJPN>, Media Type ID: <D01>, Product revision number: 67
Disc Application Code: 0, Extended Information Indicators: 3
22:03:28 #7 Text 0 File DlgWaitCD.cpp, Line 500
>>> Protocol of DlgWaitCD activities: <<<
22:03:28 #8 Text 0 File ThreadedTransferInterface.cpp, Line 739
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 3692000 (3692000) = #3692000/820:26.50
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 3692000 blocks [D: HL-DT-ST DVDRAM GH22LS50]
22:03:28 #9 Text 0 File ThreadedTransferInterface.cpp, Line 941
Prepare [D: HL-DT-ST DVDRAM GH22LS50] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 7561216000, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 3692000 | 0 | 0x00
3692000 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
22:03:28 #10 Text 0 File SCSIPTICommands.cpp, Line 217
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
22:03:28 #11 Text 0 File Burncd.cpp, Line 4279
Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB)
22:03:28 #12 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
22:03:29 #13 Text 0 File Burncd.cpp, Line 4401
Cache writing successful.
22:03:29 #14 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
22:03:29 #15 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 6x (8,310 KB/s)
22:03:29 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
22:03:29 #17 Text 0 File DVDPlusDualLayer.cpp, Line 1929
GetDriveCaps: LAST LBA of layer 1 is 0
22:03:29 #18 Text 0 File DVDPlusDualLayer.cpp, Line 1452
SetDriveCaps: Set LAST LBA of layer 1 to 1845999
22:03:29 #19 Text 0 File DVDPlusDualLayer.cpp, Line 1929
GetDriveCaps: LAST LBA of layer 1 is 1845999
22:03:29 #20 Text 0 File DVDPlusDualLayer.cpp, Line 614
Disc finalized, LBA total Image size: 3692000 (7210MB), Last LBA L0: 1845999 (3605MB)
22:04:09 #21 SPTI -1066 File SCSIPassThrough.cpp, Line 215
CdRom4: SCSIStatus(x02) WinError(0) NeroError(-1066)
CDB Data: 0xAD 00 00 00 00 00 00 21 08 04 00 00
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
Sense Area: 0x70 00 05 00 00 00 00 0A AD 21 00 3E 24 00 00 C0 00 07
Buffer x060c4300: Len x804
22:04:09 #22 Text 0 File DVDPlusDualLayer.cpp, Line 1452
22:04:09 #23 Text 0 File DVDPlusDualLayer.cpp, Line 1929
22:04:09 #24 Text 0 File DVDPlusDualLayer.cpp, Line 779
L0 Data Zone Capacity set to 1846000 (1C2AF0h, 3605MB) -> OK, confirmed setting
22:04:09 #25 CDR -1205 File DVDPlusDualLayer.cpp, Line 806
Burning Layer 1
22:04:09 #26 Text 0 File DVDPlusDualLayer.cpp, Line 816
Start writing layer 1 at address 0 (0h)
Recording mode: unknown Recording Mode
22:04:09 #27 Text 0 File Cdrdrv.cpp, Line 10168
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R DL (14), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h)
Number of Layers: 2, Track Path: Opposite Track Path (OTP), Layer Type: recordable
Linear Density: 0,293 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: FCFFFF h
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 3 h
Disc Manufacturer ID: RICOHJPN
Media type ID: D01
Number of Physical format information bytes in use in ADIP up to byte 63: 64
Media Specific [16..783]:
00 00 03 52 49 43 4F 48 - 4A 50 4E 44 30 31 43 40 ...RICOHJPND01C@
25 25 37 10 00 2C 6C 00 - 2C 6C 20 1F 0C 0C 14 14 %%7..,l.,l......
02 01 01 20 00 20 1F 0C - 0C 14 14 02 01 01 20 00 ................
04 00 33 7B 5C 00 25 69 - 3A 26 1C 0A 0B 20 02 01 ..3{\.%i:&......
01 00 00 58 62 42 26 1C - 0A 0B 20 02 01 01 00 5F ...XbB&........_
84 00 00 43 66 3E 26 1C - 0A 0B 20 02 01 01 00 00 ...Cf>&.........
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
00 00 00
22:04:09 #28 Text 0 File DVDR.cpp, Line 6007
Drive: HL-DT-ST DVDRAM GH22LS50
Book Type request [LG]: DVD-ROM
Changing the Book Type was finished successfully, return code 0
22:04:09 #29 CDR -1207 File DVDR.cpp, Line 5934
Book Type automatically set to: DVD-ROM
22:04:09 #30 Text 0 File DVDPlusRW.cpp, Line 637
Start write address at LBA 0
DVD high compatibility mode: Yes
22:04:09 #31 Text 0 File CUDFTransferItem2.cpp, Line 689
GenUDF2 FS Layout:
Sectors to be written: 3692000
Session Start: Sector 0
Volume Structure: Sector [0, 256] (257 Sectors)
Meta Data: Sector [257, 394] (138 Sectors)
Data: Sector [395, 3691710] (3691316 Sectors)
After Data: Sector [3691711, 3691711] (1 Sectors)
Trailer Track: Sector [3691712, 3691999] (288 Sectors)
GenUDF2 Parameters:
PrepTime: 11-11-2010 22:03:28
UDF Revision: 1.02
UDF Partition Type: Physical
UDF Special Mode: None
Bytes per Sector: 2048
Session Start: 0
Physical Partition Start: -1
Total Capacity: 4173824
Multi Session Mode: None
Disc Type: DVD+R DL
OS Class: 0
Volume ID: MOVIES
Allow Unicode Labels: 0
Duplicate Meta Data: 1
MS Info File: 00000000
VMS Rollback File: 00000000
Create ISO bridge: 0
ECC Block Length: 16
Sparing Packet Length: 32
Allocation Unit Size: 32
Alignment Unit Size: 16
Make Writable: 0
Access Type: Read-only
22:04:09 #32 Text 0 File ThreadedTransfer.cpp, Line 273
Pipe memory size 83836800
22:11:58 #33 CDR -1206 File DVDPlusDualLayer.cpp, Line 2227
Burning Layer 2
22:11:58 #34 Text 0 File DVDPlusDualLayer.cpp, Line 2236
Perform layer 1 to 2 jump before writing at address 1846000 (1C2AF0h)
22:16:31 #35 SPTI -1039 File SCSIPassThrough.cpp, Line 215
CdRom4: SCSIStatus(x02) WinError(0) NeroError(-1039)
CDB Data: 0x2A 00 00 2B FC C0 00 00 20 00 00 00
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x09
Sense Qual: 0x02
Sense Area: 0x70 00 04 00 00 00 00 0A 35 01 04 3E 09 02
Buffer x1b7d9cc0: Len x10000
0x00 00 01 BA 44 0D 2C 06 F4 01 01 89 C3 F8 00 00
0x01 E0 07 EC 80 00 00 E3 19 7C 71 BC 73 32 EC 6E
0xFD 78 DE 70 B2 05 94 18 D9 C6 85 3B C4 B2 F9 67
22:16:31 #36 CDR -1039 File Writer.cpp, Line 306
Focus or tracking error
22:16:31 #37 SPTI -1039 File SCSIPassThrough.cpp, Line 215
CDB Data: 0x35 02 00 00 00 00 00 00 00 00 00 00
Sense Code: 0x09
Sense Qual: 0x02
Sense Area: 0x71 00 04 00 00 00 00 0A 35 01 04 3E 09 02
22:17:26 #38 Text 0 File DVDPlusRW.cpp, Line 904
EndDAO: Last written address 2882752
22:17:26 #39 CDR -1039 File WriterStatus.cpp, Line 292
22:17:26 #40 TRANSFER -24 File WriterStatus.cpp, Line 292
Could not perform end of Disc-at-once
22:17:26 #41 Text 0 File DVDPlusDualLayer.cpp, Line 1452
SetDriveCaps: Set LAST LBA of layer 1 to 0
22:17:26 #42 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 6x (8,310 KB/s)
22:17:26 #43 Text 0 File SCSIPTICommands.cpp, Line 267
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
22:17:32 #44 Text 0 File Cdrdrv.cpp, Line 11478
DriveLocker: UnLockVolume completed
22:17:32 #45 Text 0 File SCSIPTICommands.cpp, Line 430
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
Windows Vista 6.1
AMD64
Wow64Process
WinAspi: -
NT-SPTI used
(Nero Express)
AutoRun : 1
Excluded drive IDs:
BUFE : 0
11.11.2010
UDF compilation
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
UDF Mode : pure
UDF Revision : 1.02
DAO infos:
MCN: ""
DAO layout:
Sense Code: 0x24
Sense Qual: 0x00
Burning Layer 1
Media type ID: D01
00 00 00
GenUDF2 FS Layout:
GenUDF2 Parameters:
UDF Revision: 1.02
Session Start: 0
Disc Type: DVD+R DL
OS Class: 0
Volume ID: MOVIES
Make Writable: 0
Burning Layer 2
Sense Code: 0x09
Sense Qual: 0x02
Sense Code: 0x09
Sense Qual: 0x02
Existing drivers:
Registry Keys:
