Yes No
Ads
Tom's Hardware > Forum > Motherboards & Memory > Memory > Issue trying to run 8gb RAM
Issue trying to run 8gb RAM @ 1600mhz
Forum Motherboards & Memory : Memory Issue trying to run 8gb RAM @ 1600mhz
Hey guys, got a question. I am using an Asus M4A79T-Deluxe mobo and 8gb of Corsair XMS3 TW3X4G1600C9DHX RAM clocked at 1600mhz, 9-9-9-24 timings. According to Asus, this mobo only supports 2 DIMMs of this particular RAM running at 1600mhz. I found on Asus's support page that you should only use the orange colored DIMMs for the 1600mhz (overclocked) RAM. Using 4 DIMMs of 2gb sticks at the 1600mhz/9-9-9-24 clock/timings may be unstable. Well, I discovered that the hard way. I would randomly get system crashes, but it was really intermittent (maybe once a week?). Right now the RAM is clocked at 1333mhz @ 9-9-9-24 timings for stability.
I should add that I ran Memtest on my config... my first test was overnight with all 8gb installed and I got 1 error reported the next morning. So today I tried testing one stick at a time, for 5 passes on each stick and it was clean. After reading the documentation on the memory support, I discovered the Capacity/Frequency stability list. This lead me to believe that running all 8gb of RAM at 1600mhz, and 9-9-9-24 timings was the issue.
So my questions are, is anyone else running a config similiar to mine with any issues? If no issues, how are you getting it to function properly? Also, why am I limited to only 2 DIMMs at 1600mhz, and have to underclock for 4 DIMMs installed?
I'm sure there is probably very little performance difference between 1333mhz and 1600mhz.... but it's just something I am curious about. I would like to fully understand how and why this isn't working :).
Thanks for any help!
Message edited by brett1042002 on 09-27-2009 at 04:28:43 AM
Reply to brett1042002
UPDATE:
Well, I may have discovered the problem. My DRAM Voltage was set to "Auto". I assumed this was setting it to the 1.8v (like the RAM needs). But the standard setting was 1.5v. I guess that is what I get for assuming. I adjusted it manually to 1.8v and will see if that does the trick. I am currently running my RAM again at 1600mhz/9-9-9-24 with all 8gb RAM installed. I'll run Memtest again overnight and see if it finds anything.
I still welcome any feedback you may have. Thanks.
EDIT: Correction, the "Auto" setting for my DRAM voltage was overvolting my RAM to 1.94v..... not undervolting it to 1.5v.
Message edited by brett1042002 on 09-27-2009 at 04:42:48 AM
Good job on fixing the DRAM voltage.
The limitation mentioned on 1600 RAM may be related to the AM3 processor. I don't know about DDR3, but with DDR2 you are limited to 2 1066 modules, have to use 800 or step down to 800 with 4 modules.
Maybe someone else can jump in on this issue.
Let us know how it comes out.
And bumping up the voltage beyond 1.8V might help also. That's assuming the 1600 rules isn't hard and fast, which it might be.
Message edited by Mongox on 09-27-2009 at 09:49:10 AM
Reply to Mongox
I have the same memory in my game machine, 8GB DDR3 9,9,9,24 1333 1.82v, seems to be the best setting for my machine.
------------------------------ ASUS Sabertooth X79, i7- 3930K 4.55GHz, 32GB of Corsair Vengeance DDR3, 2 EVGA GTX 580's SLI, Thermaltake 1000W PSU, Thermaltake Xaser VI Case, Acer 27" 120Hz, Water cooled, W7 64 bit Pro http://www.youtube.com/user/BadDadOne
Reply to baddad
Turned out to be Bad RAM. I ran Memtest on the modules and found the bad stick(s). Good thing Corsair has a limetime warranty on them :).
------------------------------ Mobo: Asus M4A79T Deluxe | CPU: Phenom II 955 BE @ 3.6GHz | Cooler: TRUE Black HS Rev.C | RAM: 8GB @ 1333MHz | Case: Antec 1200 | PSU: Corsair 650TX | GPU: Asus 5870 | SSD: Intel X-25m 80GB | HDD: Seagate 640GB | OS: Win 7 Pro 64-bit |
Sounds good brett - glad you tracked it down! And with 4 sticks, you're not dead while getting the bad one(s) replaced!
Reply to Mongox
There are 2091 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Low profile ram for sabertooth 990fx?
By abekl, 1 hour ago:
Gskill and corsair ram are both very goos brands - on par with one another. I picked the...
Best offers
Top experts
