Need some help!
Forum Motherboards & Memory : Memory - Need some help!
Hello Every1! i just joined and i'm pleased to b a member. So here's my first question and i'm hoping some1 can help. I just upgraded my system to Intel Core 2 Quad Q8200, XFX nForce 750i Sly MB, ATX 750w PS, OCZ 4Gig Dual channel 800mhz ram, and an NVIDIA Geforce GTX 280 video card. Now when i load cpu-z, and look at the memory tab it shows in the channels #Single, i know my ram is dual channel, also in the DRAM Frequency it only shows 400 MHz. The Voltage 4 my RAM reads 1.8V, i think i have to bump it up too 2.2V, can any1 help me with this please? P.P.S how do i get CPU-Z to read Dual channel instead of single?
Sponsored Links
Is your RAM installed in the correct slots for dual channel? 400 MHz is fine. DDR2-800 operates at 400 MHz x 2.
Reply to GhislainG
Your motherboard is an XFX MB-750I-72P9 - good to put it that way to make it easier for others to help. I like the idea of it being Sly though!
Definitely increase the voltage to 2.2V.
I'm taking back all the nice things I said in another thread about XFX's manuals. This one is lousy, at least the explantion about what slots to use. The diagram makes no sense at all. I do love their MoBo Guide though, everyone needs a copy of this thing. Actually teaches you how to assemble your system without a case, using the motherboard box, anti-static sleeve, etc... Of course, gotta register at the XFX site to get it! LOL
Heck, I know what this diagram is supposed to be saying and still can't figure it out. Aren't 3 of these diagrams identical? And isn't Channel A one green slot and one black slot? Dual-Channel is having one pair in the green slots? ie, dual channel is one stick in Channel A and one in Channel B?
http://home.roadrunner.com/~expertpc/toms/xfxslots.jpg
Put your RAM in the 1st and 3rd slots. That should take care of the problem. The dual-channel "pairs" always go in the same color. I think that will be Green slots. Ignore what the manual says - Pair A should go in Green, Pair B should go in Black.
Good luck. I'll leave you with one more pic from that manual - I may set this up in my Sig or Icon!!! Not sure if this is REALLY BIG RAM or a really small technician! Ya think XFX is employing some of those Oompa-Loompas that Willy Wonka made famous? I love it!
http://home.roadrunner.com/~expertpc/toms/handsonram.jpg
Message quoted 1 times
Message edited by mongox on 09-27-2009 at 09:42:06 AM
Reply to mongox
OK, one more! If someone even comes close to me with the "golden finger" I'm gonna cut the thing off!
http://home.roadrunner.com/~expertpc/toms/goldenfinger.jpg
But really, who can hate a company that tells you to test your system like this!
http://home.roadrunner.com/~expertpc/toms/xfxtestbench.jpg
Message edited by mongox on 09-27-2009 at 09:38:31 AM
Reply to mongox
http://home.roadrunner.com/~expert [...] sonram.jpg
Thank u very much for your help!. The first and third slots worked for my dual channel problem. I'm sorry i took so long to reply. i appreciate all the research and help you have provided.
Reply to Hoose_27
Reply to Hoose_27
Tom's Hardware > Forum > Motherboards & Memory > Memory > Need some help!
There are 797 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
