Heeeeelp plzzz!!!! format problem
Hi
I need to format my PC but I have e very disturbing problem.
when I restart my PC the PC canät read the DVD Disk. I don't know why. I tried many differents DVDs and three windowses lika 7 and vista. I even tryed the boost settings and none did work. Am gonna kill myself. I just bought this PC for 1 month ago.
Thanx for any usefull help !
9 answers Last reply
More about heeeeelp plzzz format problem
  1. Do you mean that you can't read the DVD from within windows, or that it doesn't boot from it at startup?
    like you said can't read the DVD from within windows at startup of the PC when I need to format!
  3. Is the BIOS set to boot from the dvd first?
  4. ^Exactly what I was thinking^
    You need to go into BIOS by holding either delete or F2 (it should tell you what key to press on one of the first splash screens that comes up) and find an option to set boot order. Change it so that the DVD drive is first in the list, save changes, and re-boot.
  5. 1. Does your BIOS see the DVD ?
    2. What's the Boot priority order ?
    3. Does the DVD work in another machine ?
    I did that many many times and it didn't work :(
    I have Intel Core™ i7 Quad Processor i7-950
    ASUS P6X58D-E
    6GB of RAM
    1000Watt power supply
    LG DVD Reader
    When the PC starts up with the old windows which i have within it right now, It can read the DVD who has the windows in it. But when I restart the PC It can't read it at all.
    Yes it is first and I am a 100% sure.
  9. Have you EVER been able to boot from a CD/DVD on this computer? Some SATA optical drives are not bootable...
    The New Number Two
DVD Drives Windows Vista Format Storage
