Tom's Hardware > Forum > CPU & Components > CPUs > Need Help With System Temperatures
Forum CPU & Components : CPUs - Need Help With System Temperatures
System :
2.0A Ghz P4 @ 2.25Ghz + Coolermaster CPU fan
Biostar P4M900-M4 Motherboard
1GB DDR2 533Mhz RAM
460W CoolerMaster PSU
CoolerMaster Elite 335 + 2 120MM system fans
I have to use SpeedFan since CoreTemp and RealTemp won't work with the CPU and motherboard.
SpeedFan gives me
7C - For CPU (Which is correct, since the BIOS reports the same. I am using a P4 Prescott fan)
40C - For Nvidia GeForce 8400GS
Then it shows IT8781 at 127C, 127C, and 5C what sensor is this for? The 127C,127C readings do not change. However the 5C reading goes up to 16C. It contantly stays at 127C even though the room temperature is around 25C.
http://i644.photobucket.com/albums/uu164/KHJ809/untitled-2.jpg
EDIT : Looking at the picture now, I noticethat the 7C doesn't change, I'm starting to think this isn't a CPU temp
In the config it lists the ACPI as 7C and all the three IT8718 sensors at 127c, 127c and 17+C
Message edited by AKM880 on 07-15-2009 at 04:43:11 AM
Sponsored Links
Do you have problems with your system? Except for the8400GS, none of your temperatures are correct. Your CPU temperature can't be only 7°C, no matter what the BIOS says. Why not try Motherboard Monitor: http://www.download3k.com/System-U [...] itor.html. It's outdated, but so is your hardware. Don't assume that the sensors on your motherboard are correct.
Reply to GhislainG
- 0 +
Well I checked the BIOS and definitely the 7C is not the CPU reading, the CPU is around 30C idle.
Reply to AKM880
There are 1283 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
