Tom's Hardware > Forum > CPU & Components > Sound Cards > A question about sound systems and sound cards
Forum CPU & Components : Sound Cards - A question about sound systems and sound cards
Right now, i have the Logitech X-540 speakers and i love them, but i dont think they deliver enough thump. So i was wondering, is it possible for me to hook up the Logitech Z2300 speakers and sub woofer and my original 5 X-540 speakers and dump the X-540 sub woofer? So i would have 7.1 surround sound with two different types of speakers and the Z2300 sub woofer?
And a question about sound cards,
Is it really worth it to buy another sound card for $100? I listen to a lot of music so i can tell the difference... but is the $100 sound card going to be A LOT better than the integrated sound like the Realtek ALC1200?
Sponsored Links
Quote :
Not possible unfortunately as all satellite are connected to the sub woofer first, then from sub woofer to the sound card. The sub woofer amplifies those satellite speakers so connecting them straight into the sound card (with 3.5mm instead of RCA) won't do.
Quote :
Doubt you'll hear the difference with low/mid-range (relatively compared to home theater) speakers like X-540.
Most of the DAC used with Realtek HD Audio codec chip like ALC1200 found in modern motherboard are fairly good quality already. Good enough for mid-priced computer speakers (analogue).
Message edited by wuzy on 07-16-2009 at 12:46:07 AM
------------------------------ GTL Ref Tweaking Guide - PM for detail
Brand is for the weak-minded, only product matters.
Resilient to marketing.
http://farm3.static.flickr.com/2520/3850950213_aea6bbbcfe_o.jpg
Reply to wuzy
- 0 +
oh alright thanks.
So the x-540 speaker satellites can't even connect to the z2300 sub woofer?
Reply to jchan
- 0 +
haven't looked at those speaker but like wuzzy said usually computer speakers are powered by the an amp in the sub making your proposal unlikely
As to the sound card that depends on you and your speakers. To be honest with these questions and those speakers you probably won't know the difference.
If you wanted to upgrade your sound, a decent and reasonably price solution for music would be.
Logitech Z-2300 and a xonar d1 roughly 200bucks on newegg
------------------------------ E8400 : GA-EP35-DS3L : mushkin 4GB DDR2 800 : HD 2600PRO : 450W ATX12V : Windows 7
Reply to 505090
- 0 +
I use the Logitech Z-2300s (awesome system for the money fyi) and as I recall I had a pretty noticeable difference in music sound quality between my X-Fi xtreme music sound card and an onboard realtek (don't recall what chip exactly).
I would say it is worth it if you listen to a lot of music and quality is important to you. It's one of those components that you can feel good about investing in because it will last you through multiple systems and if you plan to do any sort of gaming then a sound card is a shoo-in.
Also, realtek is just plain icky in my book.
Reply to spinny
- 0 +
spinny- thanks i was thinking that also, ill look into the x-fi extreme
505090- thanks . I was hoping it would hook up haha. i really like surround sound though, so i'm gonna have to debate if i'm gonna get z2300's or not
Reply to jchan
- 0 +
in my experience surround speakers rarely work well with computers
I have only seen one computer room laid out with proper speaker placement and the integrated wires are usually to short to put the speakers where they belong anyway
also music is recorded in two channels
In a 5.1 system the amps power is distributed to all channels while the music is only coming out of fl fr s so a lot of power is wasted. Now logitech was kind enough to a matrix function on my z5500 that will force it to use all channels problem is there goes my sound quality
Reply to 505090
- 0 +
hmm.. for my x-540's the quality seems really good already, but my computer is like 7 years old, so if i buy a new sound card, i bet the quality will astonish me... When i turn off matrix in my games, i can hear the difference... especially in starcraft. Maybe i have good ears? 0.o
Also, does anyone know how HT l Omega sound cards are?
They are all really expensive, but this one seems to be in my limit and it has decent reviews.
http://www.newegg.com/Product/Prod [...] 6829271001
Reply to jchan
- 0 +
haven't used that card but i have used the xonar d1 same price and a great card
Reply to 505090
Xonar DX. The D1 is more or less obsolete, and the DX has moved into that segment. Heck, the DX, ASUS's budget card, competes against the Forte and Titanium, what does that tell you?
http://www.newegg.com/Product/Prod [...] xonar%20dx
------------------------------ http://valid.canardpc.com/cache/banner/622598.png
Reply to gamerk316
- 0 +
oh nice... looks pretty good. But the only problem is that its a PCI-E slot. Whats weird is that one of the reviews says that he has an ASUS M4A79T Deluxe AM3 mobo and that motherboard doesnt have that slot ...
And what does it mean when it needs a floppy power connection?
Reply to jchan
- 0 +
Quote :
The connector that's been left out in cold with modern builds:
http://img.tomshardware.com/us/2007/08/09/pc_power_supplies/floppy-power.jpg
FYI, the PCIe version needed the floppy power connector because the card was designed to run on 5V provided by PCI. The PCIe version uses a PCI->PCIe bridge chip and PCIe slot provided only 3.3V. Therefore external power was needed.
Reply to wuzy
- 0 +
oh i think i gotcha. i'm trying to fit my budget and its really tough so i'm not sure if i can afford a new sound card atm. But for future reference, i'll remember the Xonar sound cards. I hope the sound on my motherboard will suffice =/
Reply to jchan
There are 1258 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
