Hi everyone,
I've got an overclocked system that seems to be misbehaving.
When trying to boot up from cold the system just hangs and nothing is output to the screen. Fans are on as they should but nothing happens to finish the boot. From here I have to switch it off then on again and the boot completes.
If I go into the tweak menu in the BIOS I'm informed that a boot has failed
I've been in touch with Overclockers UK support a bit and theres not yet been a solution. We've mainly been tweaking the voltage for the CPU.
Any suggestions?
I'm new to Overclocking which is why I got a bundle with OCUK. With this issue happening on Cold Boot too its tricky to test as I have to make a change then wait till the next day.
My system is here:
Intel Core i7 930 2.80Ghz overclocked to 4GHz
Gigabyte X58A-UD3R (BIOS Version: FC)
6GB RAM
Power Supply - CoolerMaster Silent Pro M series 700W
One suggestion made by OCUK was that maybe its the power supply but I'm not sure and dont have a spare - it's brand new and a pretty expensive piece of kit. Any thoughts on this? Other recomendations for Power?
thanks
Ben
Any suggestions?
My system is here:
6GB RAM
thanks
Ben
