hi all i am planing on getting a passive radiator for a core 2 quad q6600 and a zotac 9300 itx plus dont know what graphics card as of yet maybe a gtx 460 or a gtx 580, plan is all about taking the heat from the pc and dumping it into the living room as i plan on geting a alphacool hf passive radiator just need a help of choice on the the radiator size for the graphics cards
1st radiator
http://www.aquatuning.co.uk/product_info.php/info/p8381_Alphacool-Cape-Cora-HF-642-Konvekt-black.html
2: http://www.aquatuning.co.uk/product_info.php/info/p9125_Alphacool-Cape-Cora-HF-1042-schwarz.html
the pump is a Laing D5-Pump 12V and the radiator will be put onto a wall in my living room why i said taking heat and dumping it.
good for the pc and good for saving your heating in a way
1st radiator
