Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Graphics Card and Display (Help me choose)
Forum Graphic & Displays : Graphics Cards - Graphics Card and Display (Help me choose)
I am building my first sweet computer and I wanted some help choosing a graphics card. My set up so far is as follows
Intel i7 920 (will overclock to ~3.8 gHz)
Asus P6T Deluxe MoBo
Apevia X-SniperG-BL Case
6GB (3 x 2GB) DDR3 Corsair Dominator PC3-12800 1600MHz RAM
So I'm looking at nVidia cards, and I'm wondering which card should I get. First question, do any of the nVidia cards support directx 10.1? Also, how does the GeForce 9800 gtx compare to the GeForce GTX 275?
What would work well with my current setup (I don't want to waste money on a card that is limited by my CPU). Please recommend what card you think I should get. Thanks :)
EDIT: I have been looking at some displays and it appears that they're max resolution is really low even though they are 26" widescreens! 1366 x 768 on a 26"?? I've got a 17" right now and I'm on 1024 x 768, how can this be?
Message edited by 1337 on 05-04-2009 at 02:50:06 AM
Sponsored Links
No Nvidia card so far supports directx 10.1. The GTX 275 completely trashes the 9800GTX. I say you buy a GTX 285(10) or an HD 4870X2(10.1) and a good monitor with a resolution of 1920x1200.
Reply to abhijith
- 0 +
Well the GTX 275 is no doubt better than the 9800GTX...
Stick with the GTX 275 as they are better value than the GTX 285...
For that card, get a 1080p(1920X1080) resolution 21"/22"/23" monitor...
Reply to gkay09
There are 527 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
