Win 7 and Net Gear WNR200 Wont Work?
StreetBobber09
I have a windows 7 latptop and the NetGear WNR 2000 N wireless router. When I put the CD in it says that its not compatible and the NETGEAR site is very confusing on what to do. Also I tried just directly connecting to it but I want to change my Security code and such. If there is something I can download or how I should connect to it change the secutiry setting that would be great because I cant connect to it wirelessly on my laptop when its running.
G
Guest
Guest
You don't need the CD or a driver to set up a router. Download the manual for how to do it manually. The Netgear site also has a pretty good user forum if you get stuck.
