Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > Connecting DVI monitor to VGA/Component receiver
Forum Graphic & Displays : TV/Video Cards - Connecting DVI monitor to VGA/Component receiver
Hi all,
I have a Dell 30 inch that only has DVI input. I want to connect my Onkyo receiver that has RCA and Component output to this monitor so that I can use that as a TV.
Is there any cable that will allow me to do this?
Thanks a lot.
[correction: the receiver has RCA and Component out, not VGA. Sorry]
Message edited by thegreenearth on 05-05-2009 at 01:59:22 AM
Sponsored Links
You have to check if the monitor input is a DVI-I (not DVI-D). If so, you could probably use something like that, but quality might not be that good as VGA cable cannot support the full 2560x1600 resolution of most 30" monitors. Other than that you either have to get a digital conversion box or get a new receiver with DVI/HDMI outputs.
------------------------------ The capacity to learn is a gift; The ability to learn is a skill; The willingness to learn is a choice. - Rebec of Ginaz
http://valid.canardpc.com/cache/banner/600609.png
Reply to Zenthar
There are 688 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
