Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > Connecting DVI monitor to VGA/Component receiver
Forum Graphic & Displays : TV/Video Cards - Connecting DVI monitor to VGA/Component receiver
Hi all,
I have a Dell 30 inch that only has DVI input. I want to connect my Onkyo receiver that has VGA and Component output to this monitor so that I can use that as a TV.
Is there any cable that will allow me to do this?
Thanks a lot.
Sponsored Links
Depending on the DVI type there are two differnet solutions. If its DVI-D you need a converter, however most likely its DVI-I in which case you can buy a cable with a DVI-I connector on one end and VGA on the other.
Something like this:
http://www.newegg.com/Product/Prod [...] 6812270223
Double check on the type of DVI connection on the monitor... essentially the DVI-I has four pins surrounding the flat long pin, the DVI-D has none.
Reply to kamel5547
There are 721 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
