I know most forums listed here are about top of the line components and features. But I've come across an interesting request from an older family member to build a 5-10 year PC that will be better than something bought in a store? Gets down to the old roots of PC building better to buy or build? I am having a lot of trouble staying within budget and still having a lasting processor...
APPROXIMATE PURCHASE DATE: Would it be better to wait until June 1st to get a free Windows 7 upgrade from Vista?
SYSTEM USAGE: BASIC needs. Web browsing, Microsoft office use, solitaire, pictures, movies etc…
PARTS NOT REQUIRED: Needs EVERYTHING (for basic needs) (can skip out on floppy drive)
PREFERRED WEBSITE(S) FOR PARTS: www.newegg.com or frys.com or tigerdirect.com
PARTS PREFERENCES: no parts preference, high emphasis on reliability on basic needs parts.
OVERCLOCKING: No over-clocking no x-fire
MONITOR RESOLUTION: Needs monitor! Emphasis on reliability. Keep within budget.
ADDITIONAL COMMENTS: This is a very basic needs computer that also included in the 700 budget is an operating system (32 bit XP) Microsoft office and a decent antivirus.
This is a build for an older relative who would like a new computer. I am finding it difficult to keep within budget with an OS, Microsoft office, and a monitor included in the build.
What I have found so far:
OS + Office + Anti-virus = ~$350?
GPU - would it better to have it on-board the MOBO? 4830 ~ $80
PSU - ??? No idea how many watts to get for just basic stuff
Monitor - ??? May be the most important part for older eyes
Case - ???? Not tooo cheap, usb accessibility would be nice. How many fans should it have?
Am I missing anything?
Ideally I’m just looking for a workstation that’s going to be around for a while (5-10 years). I don’t think that’s too unrealistic just for basic needs? Can go +or- $100 if needed, but nothing unnecessary needed on this rig. Will I be better off looking for a retail machine at Dell or HP with OS already loaded on it? (GOD FORBID BestBuy http://www.bestbuy.com/site/olspag [...] 9000050002 )
Comes to $700 after rebates. Use Open Office for an ofice suite and AVG for free anti-virus. If you NEED Microsoft Office, you can get it from Amazon for about $100.
EDIT: Ninja'd by shorstuff. My build has a faster processor, faster graphics, but slower RAM (which will make little difference in real life compared to a faster processor like the one in my build). However mine doesn't include Office. Personally, I see no reason not to use OpenOffice, it's just as good and it's free. You can put that money towards better components.
Message edited by yoyojam55 on 04-14-2009 at 12:46:05 AM
The mid-range CPU/MOBO is listed here has a onboard video card that will only Xfire with the hybrid crossfire card listed here. (out of the cards listed) If you don't mind shutting down the onboard if you choose that build and go for the better GPU, than you will need to disable the card in the bios.
Use openoffice.org to get your microsoft office utilities.
$760 with Max everything(Onboard will only Xfire with Hybrid Xfire card listed or can shut off card):
AMD Phenom 9950 2.6GHz 125W Seocket AM2+ Quad-Core - $239 w/ MOBO
http://www.newegg.com/Product/Comb [...] mbo.182223
Edit- The hybrid crossfire card has a $10 mail in rebate and most of the items have free shipping.
If you need/want a 64-bit Vista home premium, it does not effect price and can be found here.
http://www.newegg.com/Product/Prod [...] 6832116488
Message edited by affinitydesigns on 04-14-2009 at 01:37:32 AM
YoYo - Skimming out on the software is not an option. It's all about comfort level with exisiting software. I will most likely sitck with XP and Office student edition because it is familiar for them. I think I may even splurge the $25 for Norty Anti-V.
Shortstuff - Spot on with the budget well done. Although, I kind of worry about the CPU and may need to upgrade the monitor to something bigger. Nice find with the onboard GPU on the MOBO. That is what I was looking for to shave some $$. For future's sake do you think it would be better to go for an inexpensive quad core?
Affinity - Thank you for the extra options as well! Although I couldn't see the $100 needed for Microsoft office.
Has anyone heard any news on the windows 7 upgrade from Vista? Is it worth the wait?
Norton is arguably worse than avg or mcafee so thats $25 badly spent.
also Vista 64 performs better than xp64 with 4gb of ram and it looks nicer.
And finally the phenom am2+ quads aren't top of the list for anyone's processor cos they have poor performance. get a phenom II am3 quad or tri core cpu.
I also like Shortstuff's list. You could shave off a few $$ by getting DDR2-800.
There are more differences between Office 2007 and prior versions than between Open Office Org and Office. Someone more comfortable with Office 2003 and prior versions may find it easier to use Open Office. Something to consider...
I am still on the fence with using open office. I use office 2007 and it was a BIG change from 2003... And honestly, after using it for a few months I still prefer the old version... I'll have to check it out on my build to see if I can't coax him into it...
Anywho! Here is what I am thinking now for this build (turned out pretty well):
I do want to use any rebates so the RAM is actaully more expensive. I'm not willing to wait around 4 months for a $12 difference...
The cases are within $5 after shipping charges are added on... Antec 300 has free shipping.
Vista 32 bit is $35 cheaper and he won't notice the difference... May even wait till windows 7.
Shouldn't I be able to get office 2003 and Windows XP fairly cheap somewhere??? I can't believe they are still charging hundreds of dollars for this garbage.
Message edited by mountie on 04-21-2009 at 08:37:09 PM
