Tom's Hardware > Forum > Graphic & Displays > ATI > Gpuz reports my hd 4870 x2 not connected to a power suply when it is!
Forum Graphic & Displays : ATI - Gpuz reports my hd 4870 x2 not connected to a power suply when it is!
hello its me again! i have discovered this in the bios of my 4870x2:
Quote :
YOU HAVE NOT CONNECTED ONE OF YOUR VIDEO CARD POWER CONNECTORS TO THE POWER SUPPLY. PLEASE REFER TO THE 'GETTING STARTED GUIDE' FOR PROPER HARDWARE INSTALLATION.
(C) 1988-2005, ATI Technologies Inc. ATOMBIOSBK-ATI VER011.007.000.000.029564 S3B50902.100 418943 75731
I have gotten this information using gpuz and saved the bios, opening it with note pad.
not connected a power cable... What is this ment to meen!?!? I have both the cables pluged in I can clearly see it!
is their a problem with my psu????
am i using the wrong cords>>
any sugestions??
thanks!
------------------------------ http://www.speedtest.net/result/603075842.png
Australian internet at its best...
Core i7 920 @ 3.76 ghz > Thermalright u120 > Thermaltake 850w psu > Hd 5870 + 5870 vapor x
> DDR3 1600mhz > ex58ud4p
Sponsored Links
ATI recommends a minimum of 600 watts for the HD4870X2. Does your power supply come with 2 pci-e connectors? Or are you using the molex to pci-e adapters? If you are, check to see that you haven't connected all the molex's from one rail.
http://www.hardforum.com/showthread.php?t=1338900
Reply to HundredIslandsBoy
Are you actually getting a warning or what?
When you say in the bios, are you just reading the text for what would be displayed if you didn't have the power cables attached even though you have not gotten this warning?
I am confused.
------------------------------ I'm a git, deal with it.
Antec 1200,PC Power & Cooling 750,Gigabyte DS4-x48,Intel Q9550@3.4 W/Xigmatek S1283,8GB OCZ DDR2 800,ATI 4870X2,X-FI>CA 640C amp>Tannoy R300/Senn 595's
Reply to strangestranger
i have a 750 or a 850 psu, forget now actually lol! i have a red PCI 8 pin cable and a black pci 6 pin attached to it. the brand is a thermaltake tough power.
ps it is a 850 watt just checked then
Reply to heroofspirits
I am confused.
ok err.. you have used gpuz yes? if so, next to the bios information part, there is a button where you click it and you can save it to my documents.
from there i open it with note pad and it says that "refer to quote at top of page" just want to know if its a major concern
This better be a troll thread.
And why is that?
Reply to Successful_troll
Because no one can be this stupid.
Not even cute, cuddly little troll as yourself.
- 0 +
Umm, have you tried a game yet? If there really were a power issue, it wouldn't run. I think you are fine and that this is either the code for a possible message or just wrong. If a cable really were disconnected, I don't think that the computer would power up, it would instead just sit there and beep at you.
------------------------------ Phenom II X4 940 BE 3.0GHz - 1.25V > GA-MA790GP-DS4H > XFX ATI 4850 1GB > 4GB OCZ Platinum 1066MHz 5-5-5-15-2T > PCP&C 610W
Athlon II X2 250 3.0GHz > GA-MA770T-UD3P > Sapphire ATI 4650 512MB DDR3 > 4GB OCZ Platinum 1600MHz@1066MHz > XP/Win7 Enter 64
Reply to EXT64
If no power is connected, a red warning message pops up telling you so.
That is all the OP is seeing when he open up the bios file in notepad as it is the only thing not in code.
Quite frankly, he is either a dunce, or a troll.
Hyaz.
It happened to me 2.
I Have a EAH 4890 though.
I saved the gpu-z bios and opened it with Techpowerup's Radeon Bios Editor and it shows me the same warning. (YOU HAVE NOT CONNECTED ONE OF YOUR VIDEO CARD POWER CONNECTORS TO THE POWER SUPPLY. PLEASE REFER TO THE 'GETTING STARTED GUIDE' FOR PROPER HARDWARE INSTALLATION.)
I have both 4-pin cables connected to the EAH though.
Reply to HonshuWolf
wow forgot that this post existed, but yeah still have the same problem. iduhnno...
There are 1272 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
