System temperature
Recently my power supply burned out and I had it replaced. Since that time I have paid close attention to the system's temperature through System Mechanic, a product that, among other things, monitors hard drive temperature. Every day, within an hour after I turn the computer on the temperature reaches a warning stage of 104 degrees F., and slowly rises to 112-114 degrees at which time I turn the computer off. Could you advise me on what to do.
Thank you.
2 answers Last reply
More about system temperature
  1. Clean all the dust out. Make sure all fans are running. Locate the computer in a place with good air circulation.
  2. Whoever replaced the PSU probably disconnected some fans, and as tig mentioned it would not be a bad idea to blow out any dust at the same time. Run the PC with the case removed so you can see what is or isn't spinning.
Power Supplies Computers Temperature Windows XP
