Solved
Radeon 5670 Problem
So I built this a few months back and let my step son use it for playing Halo and I notice sometimes he gets a split screen - half is a solid red color and the other is the bottom half of halo. Does anyone know what is causing this? Is it the graphics card over heating? I do have a fan blowing right on the card. Here are my specs:
Rosewill Xtreme Series RX750-D-B 750W Continuous
Item #: N82E16817182069
Microsoft Windows 7 Home Premium 64-bit
Item #: N82E16832116754
GIGABYTE GA-890GPA-UD3H AM3 AMD 890GX SATA 6Gb/s
Item #: N82E16813128435
VD Burner - Bulk Black SATA Model GH24NS50
Item #: N82E16827136177
Western Digital AV-GP WD-5000AVDS 500GB SATA
Item #: N82E16822136497
Western Digital AV-GP WD-1TG (Partioned 292gb,292gb & 345gb)
G.SKILL Ripjaws Series 8GB
Item #: N82E16820231276
SAPPHIRE 100287L Radeon HD 5670
Item #: N82E16814102870
AMD Athlon II X3 435 Rana 2.9GHz Socket AM3 95W Triple-Core
Item #: N82E16819103724 ( 4th core opened up reading as Phenom 2 x4 B35 )
Antec Nine Hundred
Item #: N82E16811129021
3 answers Last reply Best Answer
More about radeon 5670 problem
  1. Best answer
    First, verify that both end of the video cable, between the PC and monitor, are firmly attached and the retaining screws tightened accordingly. Video issues like you are describing are often the result of a loose connection.
    If that doesn't solve the problem, the GPU could be overheating. If OCing, drop it back to default speeds to see if the problem goes away.
    Check these and then come back for more. Good luck!
  2. Cables are on good and tight. I checked to make sure that the drivers are up to date.It is not over clocked and there is a side fan blowing on the card. The cards fan is working. I have checked the seating of the card. I have ordered a new larger monitor which is on the way. I asked him and found out it works normally fine expect for this one particular server which he said is (Modded) in some way. Thx for your advice.
  3. Best answer selected by discboy321.
Graphics Cards Overclocking
