Solved
Power Supply Question
I have a Motherboard Asus M2N SLI and I was thinking to purchase a PSU of 850W this one my question is if my MB compatible for this PSU CORSAIR CMPSU-850TX 850W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready Active PFC Power Supply here is the link for more spec http://www.newegg.com/Product/Product.aspx?Item=N82E16817139009
9 answers Last reply Best Answer
More about power supply question
  1. Yes. It will work.
  2. AKM880 said:
    Yes. It will work.
    Thank you
  3. May I ask what system specs are that would require a 850W Corsair PSU?
    Im trying to upgrade my graphic card to GTX 275 minimum is 650 currently I have a 500W PSU. and i want to get this one cause I'm probably will get another video card GTX 270 to go to SLI let me know your
  5. You can also use a power supply calculator helped me alot
    http://www.antec.outervision.com/index.jsp
    A good quality 500W can easily power a GTX275 plus quad-core.
  7. Please list all of you system's components.
    Hello here is all my component
    Well just got the Corsair 850W the other day
    CPU Phenom 9950 quad core
    MB Asus M2N Sli Deluxe
    Graphics card Asus Nforce 7600 but just got the GIGABYTE GV-N275UD-896H GeForce GTX 275 896MB
    OS Windows Vista 64 (sucks)
    4 Gig of Memory
    What do you think about the config
  9. Best answer
    You could probably power it with either the 550W or 650W Corsair.
Power Supplies SLI Motherboards Components Product
