I know that I have been full of questions today, but (I think) that these are some of the last things that I am not sure about. I have been working on overclocking my 1075t all day long and so far I have gotten it stable @3.6GHz with stock HSF with the temps under 50c at full load. () And now I have one question and would like to ask for some help. First off my question is this in HWmoniter, what is the TMPIN0? And what is the max safe temp for it? I am thinking that that might represent the north bridge of my mobo, but I am not sure. On my stable OC of 3.6GHz it was around 60C.
Also, I am trying to get my CPU as high as possible on the stock HSF until my Zalman CNPS10X Performa arrives and I will then try to get it even higher. I want the temps to go no higher than 55C and the voltage to go no higher than 1.42 until the new cooler arrives. Any suggestions as to how I could improve on the previous Overclock to get it about as high as possible without exceeding the a fore mentioned specs? I got it to run stable @3.72GHz for about ten minutes before it blue screened, and I have done that several times now with similar specs, but I can't get it stable.
