Check the operating temperature of your video card with GPU-Z.
There are some firmware updates to deal with temperature problems.
Your power supply has enough power.
Hi there,
thanks heaps for your reply. I have downloaded GPU-Z and ran it for a while. Here is a screenshot of my results. What do you make of it? I am also downloading the latest firmware. Thanks again for your help
Exactly. Based on the symptoms of your problem - I would check and recheck your graphic card is seated properly in it's slot. Sometimes it will take a few attempts to get it right depending on your case and how bent or straight or well designed it all is.
