First system build
lli02135
7
i am planning on building my first system. i would like some advice or feedback on what i choose right or wrong. i would like to balance price and power. trying to get a good core i7 gaming system for the best price. please advise me on what i could have done better. or any compatibility issues. or anything i am missing. thanks
Case
APEVIA X-JUPITER S-Type
http://www.newegg.com/Product/Product.aspx?Item=N82E16811144203
CPU
Intel Core i7 920 Nehalem 2.66GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
MOBO
GIGABYTE GA-EX58-EXTREME
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128361
CPU Cooler
Noctua NH-U12P SE1366
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608007
PSU
ENERMAX REVOLUTION85+ ERV850EWT 850W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817194041
Memory
OCZ Platinum 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227381
Graphics
EVGA 01G-P3-1281-AR GeForce GTX 285
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130442
HDD
Western Digital Caviar Black WD1001FALS 1TB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
Blu-Ray Drive
LG Black Super Multi Blu-ray Disc Burner & HD DVD-ROM Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136137
Sound
Creative Sound Blaster X-Fi Titanium Fatal1ty Champion Series
http://www.newegg.com/Product/Product.aspx?Item=N82E16829102021
You have to put something in between the ]and [ for the link to work.
Most of these parts are very nice. I think I'll edit your post and comment on the parts to give you a clearer picture:
This is an unusual choice. For this price most people would get an Antec or Cooler master. I think the Apevia is flimsy but a decent design. Poor cable management.
Cooler Master HAF - better cooling, great cable management
Antec Twelve Hundred - looks good, good cooling, well built, not great cable management, but OK.
Yep
You really need this?
Good one.
Very quiet. You could pay less for one that puts out just a good power and has a better rep for dependability... but this unit does test out well.
Probably fine. I kinda prefer G.Skill and Corsair these days.
If you are thinking you might add a second later, I would say good.
Yep.
OK
Are you sure you need a sound card? Onboard sound is usually decent, although some of us do prefer X-Fi.
lli02135
7
thanks for the feed back. i changed some parts
Case
Antec 1200
Mobo
GIGABYTE GA-EX58-UD5
PSU
KINGWIN Mach 1 ABT-1000MA1S58-UD5
RAM
G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
and got rid of the the xi-fi and went for a sc version of the video card
lli02135
7
what do you guys think about HT OMEGA sound cards, even though i might opt out on the sound card and use the onboard.
