Pny usb memory write protected problem
my pny usb 4gb memory stick appears to have become write protected somehow.
it happened when i was writing to it.
i suspect the stick may be full of data when it occured.
the indicator light just keeps on flashing.
i have tried nearly the method suggested to resolve the poblem but to no avail.
please can yu help?
J
2 answers Last reply
More about memory write protected problem
  1. buwish said:
    HI
    I DID THE FOLLOWING AND IT MADE NO DIFERENCE:-
    1. Opened Start Menu >> Run, type regedit and press Enter, this will open
    the registry editor.
    2. Navigate to the following path:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
    I had to create the registry key StorageDevicePolicies as it did not exist.
    3. Doubled click the key WriteProtect in the right window and set the value to 0 in the Value Data Box and press OK button
    4. Restarted computer and tried copying files into USB drive.
    LIGHT ON USB DEVICE STILL FLASHING IE BUSY.
    have you any other suggestions?
    j
Flash Media PNY USB Memory Storage
