Tom's Hardware > Forum > Homebuilt Systems > New System Build > Power Supply question Good / Bad
my PC guy is saying after shipping , taxes etc the same PSU will cost me $58.71 and is suggesting the following:
http://www.sparklepower.com/pdf/ATX-350PN.pdf @ http://www.newegg.com/Product/Produc...82E16817103012
Saying that it has a bigger 12cm ball bearing etc. What do think about this PSU?
Sponsored Links
your newegg link doesn't work.
What is the specs for your system?
The sparklingpower psu i'd heavly question the quality of? I was unable to find any reviews on it. That would put a red flag in the air for me.
Reply to kubes
AMD X2 7750 CPU
Asus M3N78-VN M/B
Adata 4GB (2x2GB) ram kit
LG 2X dvd rw
western Digitial 500GB HD
Will be adding later a 60$CAD
HIS Radeon 9250 128MB DDR PCI 64bit, DVI, TV-Out OR HIS Radeon X550 128MB PCI-E w/TV & DVI
Reply to Tisaab
Well, seeing as everyone agrees that Sparkle make good PSU's, I will go with what I listed in my post above.
Thanks
Reply to Tisaab
I'd recommend this HD 4670 for $87 instead of the 9250 or x550.
http://www.newegg.ca/Product/Produ [...] 6814102820
Here's a decent 500W PSU made by OCZ for 75$CAD:
http://www.newegg.ca/Product/Produ [...] 6817341012
Reply to aevm
Thanks
Uhh who agreed on that? I disagree. I wouldn't trust any computer to a PSU that hadn't been extensively reviewed and tested. I can't find any reviews that conclude Sparklepower makes good PSUs. They did use to be a good OEM, but I wouldn't just jump to the conclusion that means the PSU you are looking at is good. I think things might have changed after they were bought by FSP
I would take a good look at aevm's suggestion.
Message edited by xthekidx on 04-16-2009 at 03:56:43 AM
------------------------------ Asus P6T & i7 920 @ 3.6ghz
GTX 260 Core 216
6gb 1443MHZ 7-7-7-18 1T OCZ Platinum
CM RC-690, CM V8 HSF
Reply to xthekidx
I wasn't saying that sparkling makes good psu's. I was stating I couldn't find any that have been reviewed. If you're looking at retails sights for their reviews this is not what we here at tom's consider a good review. Most people do not have the proper equipment to properly test PSU's. If there's one thing that customer reviews do not really mean anything, it'd be the PSU. That's why I was looking for a review sight that actually has the proper testing equipment to test one out and I couldn't find one. That's a big red flag (red meaning stop/bad). I would try to stear clear of such psu's then.
It the end though its your money and your call. All i can say is going cheap on a psu can really burn you in the long run. When a cheap psu dies (which is ussualy quicker than a good psu), not only does it take out itself it has a good chance of taking out other components in your pc. Meaning that you'll not only be replacing the psu but maybe a vidoe card or motherboard. Yes a good psu can have this happen to it but i'd say at a much lower risk rate. Poor psu's have a tendancy of overratinge their psu, where as good quilality psu's ussualy underrate their psu. Your call...
Reply to kubes
How about OCZ?
------------------------------ ATI Sapphire
AMD Athlon64(939) 3000+
O/S Win 2000 SP: 4
1GB Dual DDR 400
Reply to kbaasit
Forget the OCZ what about:
Ultra LS350 Lifetime Series 350W Power Supply - ATX, SATA-Ready, PCI-Express
O/S Win 2000 SP: 4
1GB Dual DDR 400
Reply to kbaasit
no.
OCZ 500w plus, or any corsair, silverpower, silverstone, PCP&C, Xigmatek or Hiper.
Reply to Helloworld_98
One last question... would you suggest installing XP or Vista on this non gaming system?
Thanks..
Reply to Tisaab
how much ram have you got?
If you get the HD 4670 then Vista should work well.
If you get one of those old Radeons then stick with XP, because it has much lower requirements from the GPU.
Since you have 4GB of RAM, it would be better to have Vista 64-bit than XP 32-bit, because XP 32-bit won't see the whole 4GB.
Reply to aevm
There are 810 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
