Help Best power supply Help
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Help Best power supply Help
pls help i need to pick a power supply out of these 4
hec HEC350TEWX 350W ATX12V Ver2.2 80 PLUS Certified Active PFC Power Supply - OEM
http://www.newegg.com/Product/Prod [...] 6817339029
PC Power & Cooling Silencer PPCS370X 370W ATX12V 80 PLUS Certified Active PFC Power Supply - Retail
http://www.newegg.com/Product/Prod [...] 6817703018
SeaSonic SS-350ET 350W ATX12V Ver.2.2 80 PLUS Certified Active PFC Power Supply - OEM
http://www.newegg.com/Product/Prod [...] 6817151060
Antec earthwatts EA380 380W Continuous Power ATX12V v2.0 80 PLUS Certified Active PFC Power Supply - Retail
http://www.newegg.com/Product/Prod [...] 6817371005
for this build all purpose budget build
and can someone tell me why rosewill power supplies are bad
Koutech IO-RC521 USB 2.0 Card Reader
http://www.newegg.com/Product/Prod [...] 6820162020
HITACHI Deskstar P7K500 500GB 3.5" SATA 3.0Gb/s Internal Hard Drive
http://www.newegg.com/Product/Prod [...] 6822145215
Rosewill R101-P-BK Black Computer Case
http://www.newegg.com/Product/Prod [...] 6811147112
Rosewill 18" Serial ATA II cable with metal latch, Model RC-18"-SA2-90-BK, Black
http://www.newegg.com/Product/Prod [...] 6812119231
GIGABYTE GA-MA78GM-US2H Micro ATX AMD Motherboard
http://www.newegg.com/Product/Prod [...] 6813128379
AMD Athlon II X2 250 3.0GHz Socket AM3 65W Dual-Core Processor
http://www.newegg.com/Product/Prod [...] 6819103681
A-DATA G series 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
http://www.newegg.com/Product/Prod [...] 6820211281
Dell - 19" Widescreen Flat-Panel LCD Monitor
http://www.bestbuy.com/site/olspag [...] 8092173453
thank u very much
Sponsored Links
Take the HEC out of contention, then flip a coin or throw a dart or something, it's hard to go wrong with any of the remaining choices.
------------------------------ q9650 @ 4.050 | Asus Rampage Formula | 2x2 & 2x1 Corsair Dominators | WD Black 640 x2
EVGA GTX260 Core216 @ 686/1479/1103 | Antec TPN 750
Reply to Delluser1
- 0 +
I found most of the links broken.
You won't need to purchase SATA cables - the motheboard comes with it.
The PSUs you listed are good - PC Power and Cooling, Antec Earthwatts, and Seasonic.
Is there a reason you want a Rosewill PSU?
Rosewill does not make PSUs to the standards like PC Power and Cooling, Corsair, Antec, etc. It's not just efficiency or total wattage you have to consider. You need to watch the power on certain rails, the ripple of power down certain lines, etc.
Rosewill is not who I would trust my power to.
------------------------------ Antec 900, MSI P7N Diamond, E8400,
4 GB (2 x 2GB) Crucial Ballistix 4-4-4-12, 8800 GTS 512 SLI
Reply to huron
- 0 +
I don't see a video card listed. Of those listed, I'd go for the pc power and cooling for a single video card setup. Rosewill is a generic brand name used only by Newegg. It's a crapshoot as to quality and performance. It depends on which model Rosewill you select. I'd spend a little more for a quality brand with good warranty, such as corsair, pc power and cooling, or seasonic. Antec is also good, and I've dealt with their warranty service, which is first rate.
Reply to o1die
OCZ makes great power supplies at a good price and they back their products.
They also own PC Power and Cooling.
------------------------------ P965/Q6700@3.2 8MB HD4850 OC Edition
4GB Corsair XMS 800
Vista64/Win7
Fatality 550w/Antec 300
Reply to zipzoomflyhigh
- 0 +
Yes, but PC P&C PSU's are built to higher standards.
GM owns Chevrolet and Cadillac. Which is built to higher standards?
Message edited by jsc on 07-21-2009 at 08:32:44 PM
Reply to jsc
- 0 +
Nice comparison jsc - put it perfectly.
Reply to huron
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Help Best power supply Help
There are 555 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
