Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > Power Supply Question for the GTS 250
Forum Graphics & Displays : Graphics Cards Power Supply Question for the GTS 250
Hi,
I have an Dell XPS 420 that came with an 8800 GTX 768mb and a 425w power supply.
A few days ago the 8800 card became too damaged to start the computer up, so I'm in the hunt for a new card.
I'm concerned about the 450w and 24A requirement for the GTS 250.
Here are the specs for my Dell power supply:
Input: 100-240 ~ 17A 50-60Hz
Output:
+5V==/22A max -12V==/1A max
+5V(FP)==/4A max +3.3V==17A max
+12VA==/18A +12VB==/18A +12VC==/18A
combined power on +3.3V and +5V rails not exceed 150w
combined power on +12VA and +12VB and +12VC not exceed 410w
max continuous total DC output shall not exceed 425w
Model Number: L425-00
I'm not sure of the 12v rating on the card, but 410/12 = around 34.. does that sound right? Is this enough for a GTS 250?
Reply to naddie
The 9800GTX/GTX+/GTS250 will actually use less power than the 8800GTX.
Dell PSUs are underrated, and the requirements are overrated.
------------------------------ i7 920, E5300
GTX260, HD4870, HD4830
Reply to Bluescreendeath
- 0 +
If is worth a try because it is very close. However, I found that even on my high quality 450W corsair PSU was not able to give the card enough power (which I thought was very stange). I would recommend 500W+ PSU just to be sure!!
Reply to Hammeh
- 0 +
BlueScreenDeath is 100% correct. On every point.
Reply to coozie7
hellz yeh :D
thxs
Message edited by Bluescreendeath on 05-08-2009 at 08:11:32 PM
- 0 +
So just to make sure I'm understanding this correctly.. The Dell 425w is more than capable of handling a GTS 250, since Dell rates their psu's continuous output and not max like most other psu's?
Also, based on those 12v rail specs, does it have 34A?
And since I had an 8800 GTX, anything lower than the GTX 260 should be fine?
One more dumb question.. Would it be better for power consumption if a card has 1 6-pin connector instead of 2?
Reply to naddie
34amps is for the consumption for the entire PC....and it really doesn't need that much. As long as you have 20amps, you're good to go.
The 8800GTX is power hungry, so yes, you should be fine...I think even a single GTX260 should be fine.
The connectors just determine how much energy it needs. The 9800GTX/GTX+/GTS250 are all basically the same card. The latter just use slightly less energy than the former. Since the former card just slightly used more energy than what could be delivered via the slot and 1 connector, it required 2 connectors. So reducing its power consumption slightly allowed it to only run on 1 connector.
There are 1863 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Help appreciated
By 2fast4thetown_down, 4 hours ago:
If you have a 400 or more psu you should be fine it seems to be compatable just look at...
Best offers
Top experts
