how do i get ddr2 kingston hyperx ram (1066mhz)
to work in a ga ma790xds4 mb (gigabyte) i have a phenom 2 955 BE in and i tried to manually set the bios to do 1066mhz when it run windows it crashed set back to 800mhz was fine neone able to help me? i have the Bios as version f9 btw
More than likely you are going to need to change the voltage. The 5-1066 models I looked at were rated at over 2.0v and the default voltage of most DDR2 MoBo is 1.8v
Although the Kingston's state high voltages you maybe able to run them under volted (ie... my Reapers are rated 2.35v, currently running 2.26v @1100)
it still won't boot windows properly also I had difficulty finding where to put the 15 because there was nowhere in the list in the bios mentioning row active delay or RAS active delay
thank you for your help
Looking at the bios screen (I'm using the one below as a reference), set the memory to 1066, then change all the timings to what they read under SPD, unless that matches the auto, then just set it to auto.
http://forums.tweaktown.com/attach [...] ttach1.jpg
this still doesn't work ( I have tried the idea out) just ordered a new motherboard
also i received a reply from gigabyte telling me this current motherboard only accepts 2 slots occupied so I tried removing 2 of the sticks and have given up
thanks for the assistance in this
