I recently bought and assembled a new system mainly geared towards gaming. Specs follow:
Mobo: ASUS P5Q3 Deluxe WiFi
CPU: Intel Core2Quad Q9300
RAM: Corsair TWIN3X4096-1600C7DHXIN
GPU: HIS Radeon HD 4870X2
PSU: Corsair HX1000W
OS: Windows Vista Ultimate 32bit
I've had lots of trouble getting the motherboard and RAM to function well together, and I am still unable to run the RAM at listed speed due to CPU overheating with the increased FSB.
I started out with a different brand of memory, and swapped them for these Corsair ones after I found out the ones I had simply would not work properly. After that, it seemed stable enough.
The problem I'm having now is that whenever I run any new high-end game, it always crashes to desktop after about an hour and a half. (Crysis: Warhead, Demigod, Empire: Total War, Dawn of War II, EndWar)
At first I just figured that it was a software issue, but it's too consistent, so I decided to run Memtest86+ 2.11 overnight, and I yielded 4 errors, 3 on test #7 pass 10 and one on test #7 pass 12. So it took about 8 hours before any errors were found...
Im pretty sure there's nothing wrong with the memory sticks, so I'm thinking its either a BIOS issue or possibly something wrong with the motherboard itself.
I just recently ordered a new CPU cooler, so I can bump the FSB up to 1600MHz and run the RAM at its listed speed.
Maybe that will help, although I doubt it...
Any help in resolving the issue is much appreciated :S
