Tom's Hardware > Forum > Graphic & Displays > ATI > HD 4850 driver problem
Hi.I am running Vista 64bit sp1.GPU : HD4850 512MB..After installing drivers(i tried a lot ) the PC after loading VISTA restarts(diplay has no signal and is black)...can somebody help? :(
Sponsored Links
Give more info please :)
-How the installing windows passed? were there problems?
-Are you install the drivers on a fresh instaled Win? (there could be problems if you update exisiting drivers)
I am with HD4850x2 myself, had no problems installing drivers on Win XP 64 bit.
Are you sure the drivers are for the right version of Windows. They Must be exactly for Vista 64-bit, except if there is an explicit note that they are compatible for both 32 and 64 bit versions of Windows vista (unlikely).
Reply to Ivan Ivanov
the installing passed without problems..I have installed drivers right after windows installation...Exact drivers for Vista 64bit Hd4800 series...
Reply to samki_rock
- 0 +
Could you give computer specs (could be a hardware issue too).
Try booting in safe mode and uninstalling the drivers (then restart, then reinstall).
Also, only have 1 monitor hooked up (and to the main plug).
------------------------------ Phenom II X4 940 BE 3.0GHz - 1.25V > GA-MA790GP-DS4H > XFX ATI 4850 1GB > 4GB OCZ Platinum 1066MHz 5-5-5-15-2T > PCP&C 610W
Athlon II X2 250 3.0GHz > GA-MA770T-UD3P > Sapphire ATI 4650 512MB DDR3 > 4GB OCZ Platinum 1600MHz@1066MHz > XP/Win7 Enter 64
Reply to EXT64
CPU: Phenom II x4 940
GPU: HD4850 Sapphire
MB: GA 790x-UD4
PSU: 550w CoolerMaster
I tried that many times but no changes...There is one option of functioning...When I install the driver without Catalyst Control Center, the computer starts for a first time...but after another restart there is 20%chance of getting to Vista(sorry for my english)
Do you think that flashing new BIOS would help?I read on some forums about the same problem with HD4850 and i did not found exact solution...Only solution I found is that without installing CCC,but it is useless when I want to reboot my PC
Reply to samki_rock
- 0 +
Hmm, one (possibly random and probably not helpful) idea. When you installed your motherboard, the standoffs were metal and you didn't put any insulating washers between the screws and the MB, correct?
Reply to EXT64
I did that exactely like in the installation guide
Reply to samki_rock
and sometimes after booting Vista the screen goes blue and then goes restart
Reply to samki_rock
- 0 +
You could try updating your MB BIOS (can't hurt) and do a careful check to make sure all the BIOS settings are correct. Also, if this is a new build I would recommend reinstalling Windows and starting over. Then, maybe try the drivers from the CD first (or the newest from online if you already tried the CD ones first).
Also, I may be wrong on this, but you may be able to turn off the Vista autorestart so you can actually read the Blue screen (assuming it says something). Also, check you system logs to see if it lists a cause or suspect.
Reply to EXT64
THX a lot....I will try flash the BIOS.Where can I find newest BIOS for Sapphire?
Reply to samki_rock
quick note - I had vista 64 installed with a Sapphire 4850 and the latest drivers (9.**), it continued to give me BSoD, I'm fortunate enough to be a college student with access to the every version of windows, so installed vista 32 and the recent drivers worked fine, so I went back to my vista64 and installed some older drivers (8.8) and they worked fine, the major difference between the new (9.**) and the old (8.8) is the CCC "overclocking" isn't present in the 8.8 drivers...
try and find the older drivers, that might work... (I had a disk, or I'd give you the link)
-jt
Message edited by taylorjes on 05-08-2009 at 07:51:57 PM
Reply to taylorjes
Yeah I would be greatful if you gave me the link :)
Reply to samki_rock
and I dont understand why ATI doesnt solve this problem...There are a lot of people with the same issue :(
Reply to samki_rock
- 0 +
Yeah, sorry I was referring to the Motherboard BIOS. Card BIOSes are much harder to come by (and I have no clue where to find them).
If you are referring to older drivers:
http://support.amd.com/us/gpudownl [...] sta64.aspx
That's back a year or so.
Reply to EXT64
thanks, and do you think that flashing cards BIOS(if i found one) would help?
Reply to samki_rock
and what do you think?which one MB BIOS would help?
http://www.gigabyte.com.tw/Support [...] #anchor_os
I am running F2 now.
Message edited by samki_rock on 05-09-2009 at 09:31:03 AM
Reply to samki_rock
- 0 +
Hmm, yours is weird (as it has an F2 newer than an F3). Maybe a MB BIOS flash isn't worth it, but you should at least reset the BIOS to default and reenter everything just to be safe. If you would like to try one, there is no harm in it (I've flashed my gigabyte board several times and they normally make improvements). Maybe try the F3 one.
As for a card BIOS, I've never messed with that before so I don't know. It depends on what the problem with your card is.
When it does run, have you gotten a chance to run a program that will stress it? Like 3D Mark or a game?
Also, have you gotten a chance to run a older driver?
Reply to EXT64
yes...when it does run,i can play game or benchmark....but CCC has no Ati overdrive option...and after rebooting PC the black screen is back :(
Reply to samki_rock
- 0 +
Was there any random software that came on your driver CD (like mine came with a card health program)? When I uninstalled those, the comp started saying there was no video driver and doing weird things. Maybe install those if you have any.
Also, in what driver version is Overdrive not showing up? They just put out a new version of it, maybe that new one is incompatible with your card BIOS.
Reply to EXT64
- 0 +
You probably already saw this thread, but it may have some advice (to at least compare to what you did). The end result isn't favorable though, as the guy justr gave up and bought a 260.
http://techreport.com/forums/viewt [...] =3&t=65859
Reply to EXT64
yeah you are right.I just installed driver 9.4 and the Ati overdrive is there...but the problem stays...
http://forums.amd.com/game/message [...] TMP=Linear
a lot of people with same problem.And they say that this problem came up long time ago and it is not fixed yet :(
Reply to samki_rock
- 0 +
Just to confirm, it reboots after losing signal on its own (in other words, you don't just lose signal).
Reply to EXT64
After booting into vista(when the windows sign should show up)...the screen is black and right after about 10 sec. it reboots
Reply to samki_rock
- 0 +
Well, you could try using non-DVI (VGA cable) or another monitor to see if that helps (also check if it detecting your monitor correctly). Could also try installing the drivers, then going in in safe mode and turning all the Graphics settings down low, then reboot. And one last ditch effort, turn off USB legacy detect in BIOS.
Message edited by EXT64 on 05-09-2009 at 05:11:13 PM
Reply to EXT64
There are 1123 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
