Closed
My twin usb vibration joystick problem please help me
Last response: in Components
i have a problem in my Chinese twin usb vibration joystick
this problem exist even i install vibration driver or not and even i update the diver
when i plug it
the two analog sticks works fine
but after period of time hour or two hours i dont remember it always the two sticks stucks
like in the picture and icant move it or calibrate it ..... when i replug the gamepad the two sticks works fine again
then the problem repeats itself again after hour or two hours too and it works fine after replug it too and like that again and again......
what is the problem and how ican solve it?
please help me
thanks
i tried reistall and update the gamepad driver alot of times but doesnt work
and i updated the motherbord drivers but doesnt work also
but if there is failure in the gamepad why it works fine for aperiod of time after replug it?
thank you for your reply
Hmmmm... if you can try out the gadget for an appreciable time on another computer, do so. It could be a hardware error or a software error, and this is a way to know for sure.
Related ressources
Hey guys after spending days (literally DAYS) trying to find a driver for my twin USB gamepad i got one ! My gamepad is a saitake twin USB Gamepad but this driver might work with other gamepads, because this driver says it's for the twin PS to PC converter, but still detects my gamepad, with vibration feature.
Heres the link to driver: http://www.saitake.com/downloads/setup.rar
tested on XP, and windows 7 64 bit
when i plug it
http://img31.imageshack.us/img31/605/40948164.jpg
please help me
thanks
how do you move 3rz and 4z?? :S
Ask the community
