Hello,
I have finally built my new i7 machine. Here are the specs:
CPU - Intel Core i7 920
Mobo - ASUS P6T Deluxe V2 LGA 1366 Intel X58 ATX Intel
GPU - SAPPHIRE 100259-1GL Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire
Mem - OCZ Platinum 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model OCZ3P1600LV6GK
PSU - COOLER MASTER RS-700-AMBA-D3 700W ATX12V V2.3 SLI Certified CrossFire Ready 80 PLUS Certified Modular Power Supply
HDD - Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s Hard Drive
Case - COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case
DVD Drive - LITE-ON 22X DVD Burner with LightScribe Black SATA Model iHAS222-06
OS - Microsoft Vista Home Premium 64 Bit
Thermal Compound - Arctic Silver 5 Thermal Compound - OEM46591231
CPU Cooler - Cooler Master V8
I basically put all the pieces together, fired it up and installed Windows Vista. My questions are:
1. Are there any settings in the Bios that I need to adjust for the memory that I am using?
2. Can anyone recommend a website that has more information than the ASUS manual for configuring the system?
3. Are there any recommendations on how to improve my PCs performance?
This is my first real PC build, so this is kind of new to me.
Thanks in advance for any help that you can provide.
mike
mike
