New build i7 please help
198962
Hi, i am going to build a new i7 system
are these parts good?
case
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
$75
gpu
XFX GX260XADJF GeForce GTX 260 Core Edition Core 216 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16814150361
$170
motherboard
MSI X58 Pro LGA 1366 Intel X58 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130221
$200 rebate 180
CPU
I7
http://www.microcenter.com/single_product_results.phtml?product_id=0300438
$250
ram
G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231247
$90
hdd
Western Digital Caviar Black WD7501AALS 750GB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136283
$90
optical drive
Pioneer Black 20X DVD+R 8X DVD+RW 12X DVD+R DL 20X DVD-R 6X DVD-RW 16X DVD-ROM 40X CD-R 32X CD-RW 40X CD-ROM 2MB Cache SATA 20X DVD±R DVD Burner - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827129032
$23
power
Antec EA650 650W Continuous Power ATX12V Ver.2.2 / EPS12V version 2.91 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371015
$80
fan
Noctua NH-U12P SE1366 120mm SSO CPU Cooler - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608007
$75
thank you for your advices
