Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Graphics card problem
Forum Graphic & Displays : Graphics Cards - Graphics card problem
I just installed a new graphics card and when i turn on the computer everything else runs (fans, cpu, etc.) but the graphic card wont power up. I have all the correct plugs in what could be wrong?
Sponsored Links
Sounds like your power supply is not big enough to support the card. Can you answer a few simple questions so that we can assist you?
What graphics card is it you have installed?
How many watts does your PSU have and how many amps are available on the +12V rail? (all of this info can be found on the sticker on the side of the PSU inside the cover).
If you do need to new PSU, be sure to go for a high quality one because it is a crucial part of the system and a low spec one could damage parts of your computer. Running a PC without enough power is actually more damaging to the system than with too much. So I would recommend taking the graphics card out and putting the old one back in until this is resolved.
Reply to Hammeh
I just installed a GeForce GTX 260 Core 216, and my PSU is 600W with 18 amps available on each +12V rail.
Reply to Jwfrogs11
There are 720 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
