This is a strange problem I am having and I would like to get it fixed so I figured I would ask here. Well, the issue is I am not able to see a few sites that are up and running.
One of the sites I own, and the other site is where I got my webhosting from. The first site is http://www.deltaservers.com. You will be able to see it but I get the following error:
"Firefox can't find the server at www.deltaservers.com." I have tried it with multiple browsers and it still does not work.
The next site, which I bought from deltaservers, is http://www.legionoflulz.com. I get the same error. This problem has been going on for weeks and even a few months. Now one day, I was able to go onto both sites, and that is how I setup the legionoflulz.com one.
For some reason I can't go on any websites hosted by Deltaservers.com. Any suggestions on how to fix this? I really have no idea what to do.
By the way, I have vista and my ISP is RCN if that helps. My firewall is also disabled so that can't be the problem.
Message edited by infl1ct1on15 on 08-05-2009 at 04:43:33 AM
Disable windows defender and UAC, if you have a firewall not windows, check the politics of this....the same way in the windows firewall
------------------------------If you like my answer, select me as the best answer.
"Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.". Albert Einstein.
Reply to saint19
Also delete cookies, and run CMD, write ipconfig /flushdns...wait until the window show that the dns adress was delete...run again CMD and write ipconfig /register dns...wait until the system says that the new adress fo the dns was save....
Reply to saint19
