Well I think i have found out what causing the increase in temp in idle. The card must detect rhapsody (a music player) as 3d app and speed the cores up a little bit.
because when i open rhapsody the card runs a little hotter. and after i close it it cools back down to normal
I will have to do a GPU-Z log while playing Crysis Warhead to see the highest my temps get.
BTW i installed a another 120mm fan on the door to blow right on the card, and now my temps have dropped a great amount.
I wouldn't run the fan speed at 100%...i mean really there isn't any reason to unless going from 60/70 to 100 makes a big difference....atleast lower it to 80 as any decent case should keep that card cool...
Although i have a horrible case cooling wise...so i doubt yours can be worse than mine
To be honest, I wouldn't run your fan at 100% all the time because it is a mechanical part and therefore you are actually wearing it out more rapidly. I would suggest you lower the fan value to <80% which will help to keep it going in the future because your card is good up to about 75C under full load.
That was the reason i suggested the lower fan speed but most people just don't care since its covered in the warranty....my gtx 260 with an overclock of around 700mhz and up stays below 60c aslong as the fan speed is in the 70's...my 9800gtx+ stays way cooler...
Then again my room is always very hot and anytime i take my rigs to work they perform atleast 10c cooler under load...its ridiculous
Why do people assume that Case fans can run at 100% always but graphics cards fans don't?
If you are comfortable with the noise then run it at any speed you like, so far my 8800GT that I OC'd heavily has been a champ running at 70% fan speed, any higher than it gets annoying though, which is the main reason I haven't turned it up.
Hmmm unless your going to open your card and void the warranty to replace the fan you have to rma it...and thats if the card is under warranty in the first place...im sure you and everyone else are just dieing to find out how fun it must be to replace a gfx card fan
To be honest i would much rather replace the fan iv modded into the front of my case that runs at low RPM through an advanced cooling manifold then my not under warranty gpu fan
