Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Guitar builder needs PC building help: Can I mount my PSU upside down?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Guitar builder needs PC building help: Can I mount my PSU upside down?
I'm continuing to find out things I didn't know I needed to know and my current dilemma is...
My case doesn't have a vent directly above the PSU. It does have a vent top and center of the case and it also has vents at the top of the sides(right below the top corners).
The PSU I'm installing is a OCZ ModXStream Pro OCZ500MXSP 500W. I'm thinking I should mount my PSU upside down since I won't have a vent directly above it. Can I do this and should I?
btw, I'm not sure what case I have. It's an older Raidmax with blue lights on the front and it says 'Diamond Panel' inside.
Sponsored Links
I would mount it so the fan (one large or 2 smaller ones) faces the cpu, or fits the mounting screws. Most ps only go in one way.
Message edited by o1die on 07-23-2009 at 01:12:29 AM
Reply to o1die
u can mount it upside down, all the components will work no matter what oriantation as long as it fits n u can screw it in.
in ur case id have the fan pointing down to allow it some air flow, it will also take air from the top of the case above the CPU and push it out the back, this is good as hot air rises and u dont want hot air in the case :)
------------------------------ Q6600 @ 3Ghz
8800 Ultra
4GB OCZ 1:1 ratio
2 x 500GB WD RAID 0
Reply to mildiner86
PSU mounting holes are asymmetric, so
you can't easily flip a PSU upside down
and have all the holes line up.
My advice: get a modern case with superior
ventilation e.g. Cooler Master CM 690:
http://www.newegg.com/Product/Prod [...] 6811119137
MRFS
Reply to MRFS
yeap just try it n see if it screws in u may be lucky n it fits i have mounted one or 2 upside down before. just need things in the right place, but it will ffunction upsdie down
8800 Ultra
4GB OCZ 1:1 ratio
2 x 500GB WD RAID 0
Reply to mildiner86
Thanks, I went ahead and put it in upside and and it's working great so far.
Reply to jnasty
That is correct you don't want hot air in the case, however, I also recomend getting a new case because you don't want all the hot are running thru the PSU. Bottom mount PSU stop this problem and allow for cooler air to run thru the PSU. Cooler components, is just a good thing.
Reply to medjohnson77
There are 1114 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
