Tom's Hardware > Forum > Homebuilt Systems > New System Build > Best Bang for the buck: How much should you spend on a new system?
Forum Homebuilt Systems : New System Build - Best Bang for the buck: How much should you spend on a new system?
What is the best bang for the buck - How much should spend on that new system and how often should you upgrade?
I have been thinking for a while on what is the best system building strategy with regards to getting the best "play-ability" in games for the least amount of money over a long period of time. Here is a comparison I did between Toms system builds throughout the years, and I came to the conclusion that spending about $500-750 every tick or tock in Intel's or AMD's strategy time plans (every 1-2 years) on new mobo, CPU and GPUs give the best bang for the buck, but I am curious to hear your opinions on this matter.
Comparison of value over time:
Lets assume that your system requirements (or wants) is to always be able to play the newest games out there, preferably at the max details, but not necessarily:
If you buy a good case, cooler and PSU, you probably won't have to replace them often to increase performance - so lets look solely at what you do need to replace often if you want to increase performance: CPU, MOBO, RAM and GFX
In March 2007 you could have bought:
Value - $331
CPU AMD Athlon X2 3800+ AM2 $82
Motherboard MSI K9N4 Ultra-F $59
RAM Wintec AMPO PC2-6400 1 GB $70
Graphics XFX GeForce 7600 GT $120
=Playable at max settings most games 2007 (1024x768)
Mid range - $805
CPU Intel Core 2 Duo E6600 $230
Motherboard MSI P965 Platinum $135
RAM Patriot eXtreme Performance PDC22G6400LLK $160
Graphics EVGA GeForce 8800GTS PN: 320-P2-N811-AR $280
= Playable all games 2007 (1600x1200)
Enthusiast - $2655
CPU Intel Core 2 Extreme X6800 $970
Motherboard Asus Striker Extreme $330
RAM Crucial Ballistix DDR2 1000 PC2-8000 $235
Graphics 2x GeForce 8800GTX 768 MB ($560) $1120
= Playable all games 2007 (2560x1600)
In March 2008 you could have bought:
Value - $563
CPU AMD Quad Core Phenom 9500 $190.00
Motherboard Gigabyte GA-MA78GM-S2H $100.00
RAM Wintec Ampo DDR2 PC2-6400 - 2 GB $43.00
Graphics HIS Radeon 3870 ICEQ Turbo $230.00
Mid range - $1333
CPU Intel Core 2 Quad Q6700 $540
Motherboard Asus P5N-T Deluxe $250
RAM Crucial Ballistix DDR2 800 PC2-6400 - 4 GB $128
Graphics EVGA GeForce 8800GTX, 768 MB $415
Enthusiast - $2320
CPU Intel Core 2 Extreme QX9650 $1060
Motherboard Asus Striker II Formula $320
RAM Crucial Ballistix DDR2 800 PC2-6400 - 4 GB $100
Graphics 2x Gigabyte GeForce 8800GTX - GV-NX88X768H-RH $840
In March 2009 you could buy:
Value - $420
Intel core 2 duo E7400: $120
Gigabyte EP45-DS3: $100
2 x ATI Radeon 4830 : $150
G Skill 2x2GB PC8500 DDR2: $50
Mid range - $685
AMD Phenom II 940: $215
ATI Radeon 4890 1 GB $230
Gigabyte 790 UD4H: $140
G Skill DDR3 1600Mhz 4GB: $100
Enthusiast - $1756
Core i7 920: $280
2 x Nvidia GTX 295 $500
MSI X58 Eclipse SLI Intel X58 $310
CORSAIR DOMINATOR 6GB DDR3 1600Mhz $166
Evaluation
We are looking at things from a budget perspective here, so this is the most important consideration in this evaluation- Namely: What is the best bang for the buck?
Now you will be of course thinking to yourself that value is a relative term - and yes, you are correct. However there is an easy way we can simplify it - basically good value is getting a system that does what you need it to do at the cheapest price. If it excels doing this, then best value will of course be a determination of whether or not the extra performance scales linearly with the price premium. The X to Y graph of performance to price in computing generally looks like this:
http://farm4.static.flickr.com/3642/3495379476_40d987f03c.jpg?v=0
The sweet spot for gamers is what we are trying to find here. Now consider that most gamers will be using 1600 or 1900 res nowdays - but 1200 and 1400 res were common in 2007 - The goals there change over time - but playability is the main priority.
So simply put - the objective in 2007 was 30 fps in games at high settings and 1400 res.
In 2008 it was 30 fps in games at high settings and 1600 res.
In 2009 it is 30 fps in games at high settings and 1900 res.
So this comparison will evaluate what was the sweet spot to achieve this - was it to build the cheapest system that just meets the specs each year - or have an uber system that lasts 3 years, i.e. "futureproof"?
Now lets look if you bought the cheapest of these systems and (important!) overclocked each of them,
I think you will be surprised:
Buying only value systems each year:
2007 bargain system plays all 2007 games, 2008 system bargain plays all 2008 games, 2009 bargain system plays all 2009 games.
So you have to buy 1 bargain system each year: $331 + $563 + $420 = $1314
So in three years you spent a total of $1314
Buying the Enthusiast option to "Future Proof" yourself long term?
If however you had bought the most expensive system in 2007 it would cost you $2655, hehe and guess what .... It gets trashed like a pikey up against the overclocked bargain 2009 system. lol lol lol - so you would have wasted a lot of money there, in fact it only beats the bargain 2008 system so you lose 2655- 331-563= $1761 - ouch!
Buying the mid range system to "Future Proof" your self short term?
What if you bought the medium range systems? Well the 2007 medium system gets trounced on by the 2008 bargain system, so that doesn't give you much value. The 2009 bargain system also beats the 2008 medium range system.
Ram and motherboards
Remember though that these cost analyses are just to gain perspective - they are not actually completely realistic as in several stages you could skip upgrading RAM or Motherboards - CPU and GPU upgrades are the most important, however don't by a MOBO or RAM thinking that it will last be upgradable to the best CPU/GPU for the next 2-3 years, here is why:
Look at the 2007 mid and enthusiast range MOBOs:
They were excellent for their time but are now CPU outdated due to the new socket 1366 i7 - so CPU outdated in 2 years. They are also GPU outdated as now the PCI x16 pathways are much better and offer much better scaling than in these old motherboards - so outdated compared to the new SLI/CF motherboards
Look at the 2008 mid and enthusiast range MOBOs:
These again are pretty much gonna be outdated soon because there is no option to upgrade to the new core i7 or i5. So after only a year they are no longer even close to the new enthusiast-mid range i7 CPU performance .
Look at the 2008 value MOBO:
Wow, amazingly this could be upgraded in 2009, with a small F7 BIOS download, to a AM2+ 940 phenom II or AM3 720 BE and a newer graphics card solution, for example - a 4870 1GB or 2x 4830/4850 - then you have a system that is as good as the 2009 builds, for only $250-350! I would of course not bank on this always happening, as the 2007 value system would not have upgraded so well in 2009. Added bonus is of course that you can sell the old parts on EBay - especially when they are not that outdated.
And this shows exactly why you shouldn't bet on your MOBO too much - it may provide you with a decent upgrade platform for 1, 2 or even 3 years - but only only time travellers will know for sure.
The RAM here has also been very transferable - but as it is so cheap and offers so little performance gains any way it is not so important.
How much should you spend on systems and how often should you upgrade?
So in the end your guess is as good as mine - will the 2010 bargain system trounce the 2009 medium range option? I don't know actually because the CPU prices aren't as divergent as in the previous years.
I just did this comparison to make a point that you actually save crap loads of money if you can be assed to upgrade your system every time a new generation of component comes out that really increases performance and at the same time don't spend much more than 500 bucks on CPUs, MOBOs, GFX and RAM on a yearly basis.
"Future Proofing" Is it a bunch of BS?
Then there is that other question: "Future Proofing" your system, or "Is this system future proof?" - personally I think it is one of the stupidest ideas I've ever heard. How do you future proof in a industry with the highest rate of innovation and development turnover known to man!? Well I think the answer to that is of course you can try by wasting a lot of money - but even then you may not succeed. If you really hate me for saying this I am sorry...
I just think that looking at a system as "future proof" is misleading, it should be instead called something like "potentially upgradable" or "legacy components".
The things that I think might come close to what i think is intended behind the false statement "future proof" are the components with long potential life span like a PSU, PC case, good quality air or water cooling (vapo even if you got the cash) - these are legacy components because they can work with newer generations of other components like Mobos, CPU's and GPU's.
Hard drives (maybe RAM sometimes) are also somewhat more long lasting in their relevance and can be legacy components. Mobos are then possible to consider as "potentially upgradable" because they can sometimes be upgraded with newer CPUs and GPUs. But no entire pc build is ever future proof because of the immense innovation in computing, and this goes especially for GPUs. (My opinion)
What do you guys think about this strategy/ideology? lol - ideology sounds wrong but eh
Message quoted 1 times
Message edited by nerrawg on 08-01-2009 at 05:10:28 PM
Sponsored Links
Value - $331
Mid range - $805
Enthusiast - $2655
Value - $563
Mid range - $1333
Enthusiast - $2320
Value - $420
Mid range - $685
G Skill DDR3 6GB: $100
Enthusiast - $1756
Core i7 920: $280
CORSAIR DOMINATOR 6GB DDR3 1600 $166
Evaluation
We are looking at things from a budget perspective here, so this is the most important consideration in this evaluation- Namely: What is the best bang for the buck? Now whats important to take from this is that if you bought the cheapest of these systems and (important!) overclocked each of them you would see funny things:
I think your ideology is absolutely right .
But theres the other side too . People need a car to get around .. but some buy Ford Focuses and some buy Ferrari's . There are pro's and con's of buying a Ferrari , but if you were giving away those two cars I know which one every body would choose
Reply to Outlander_04
- 0 +
I like the subject and approach.
I think your price on the 2xGTX295 is a bit off, it shound be $1000, they are $500 or so each.
Looking at the results, I think a good strategy is to buy a mid-range system with a near high end vga card, and plan on keeping it for two or three years, with an upgrade to a near high end card part way through. The highest end cpu's seem to get obsoleted very quickly. Current good cpu's seem to be able to drive any vga card very well. The vga card is the key to good gaming, and their performance is still getting better. It probably pays to upgrade them more frequently.
Reply to geofelt
hmmm....interesting article i really like alot of your ideas.
seems like a midlevel system every time the die size shrinks makes alot of sense in the long run.
future proof is definitely bull, if you mean beyond 3 months :lol:
Message edited by daidalas on 04-19-2009 at 06:49:49 AM
Reply to daidalas
- -1 +
A big plus 1 for that post!
Ok, here's an example build of what geofelt is talking about. Lifespan on this build is about 2-3 years, then save the case and psu maybe, and ebay everything else. Start out fresh with new technology and gizmo's.
http://www.newegg.com/Product/Prod [...] 6811129042 $59.95 Free Shipping*
Antec Three Hundred Black Steel ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Prod [...] 6817341022 $69.99 ($44.99 after $25.00 Mail-In Rebate)
OCZ Fatal1ty OCZ550FTY 550W ATX12V / EPS12V SLI Ready CrossFire Ready Modular Active PFC Power Supply - Retail
Free 4GB flash drive with purchase, ends 4/30
http://www.ewiz.com/detail.php?name=MB-43-UD3L $65.49 after rebate
GIGABYTE GA-EP43-UD3L Core 2 Quad/ Intel P43/ DDR2/ A&GbE/ ATX Motherboard
http://www.ewiz.com/detail.php?name=E7400 $106.75
Intel Core 2 Duo E7400 2.8GHz 1066MHz 3M LGA775 CPU, OEM
http://www.newegg.com/Product/Prod [...] 6835207004 $39.99($29.99 after $10.00 Mail-In Rebate) Free Shipping*
Sunbeam CR-CCTF 120 mm Core-Contact Freezer CPU Cooler W/TX-2 - Retail
http://www.newegg.com/Product/Prod [...] 6814150361 $169.99 Free Shipping*
XFX GX260XADJF GeForce GTX 260 Core Edition Core 216 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
Free Call of Duty: World at War w/ purchase, limited offer
http://www.newegg.com/Product/Prod [...] 6820231219 $42.99
G.SKILL HK 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Prod [...] 6822136319 $74.99 Free Shipping*
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Hard Drive - OEM
http://www.newegg.com/Product/Prod [...] 6827136152 $24.99 Free Shipping*
LG Black 22X (CAV) DVD+R 8X DVD+RW 16X DVD+R DL 22X (CAV) DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD±R DVD Burner - OEM
Total: $664.72 | $619.72 w/rebates *not including shipping
http://www.newegg.com/Product/Prod [...] 6832116488 $99.99 Free Shipping*
Microsoft Windows Vista Home Premium SP1 64-bit for System Builders - OEM
http://www.newegg.com/Product/Prod [...] 6824236050 $169.99 ($149.99 after $20.00 Mail-In Rebate) Free Shipping*
ASUS VW224U Black 22" 2ms(GTG) Widescreen LCD Monitor w/ HDCP Support 300 cd/m2 1000:1 (ASCR 5000:1) Built in Speakers - Retail
Reply to Why_Me
I think you are absolutely right that futureproofing is garbage. Potentially upgradable is as good as you can get I think.
I think spending about $700 every 1-1.5 years is probably the best approach to get the best value.
------------------------------ Asus P6T & i7 920 @ 3.6ghz
GTX 260 Core 216
6gb 1443MHZ 7-7-7-18 1T OCZ Platinum
CM RC-690, CM V8 HSF
Reply to xthekidx
Depends where you live(i live in the Philippines and you would hardly find many people here with Quad core Units they still stick to dual core unlike me though who bought a Phenom 9650 so it depends cause some even stick to Pentium 4/3 in here and mean it Pentium 3!!!!!!!) so it depends
Reply to CHRISTLUBAS
also i forgot it depends on the economy
I built my first PC in May 2006 for a total of AU$1500 (AMD 3700+, xFx 7900GT) and it has only recently died on me. It was becoming more and more obvious that the CPU was the bottleneck, as I was still able to play recent games (CoD4, GRAW2) on low settings up until about a month ago.
I agree with geofelt and Why_Me when they say to aim for a midrange system. This is a theory that works for me because I just can't justify an annual upgrading process; at least not while I'm still studying ;)
I'm planning to build a completely new box within the next month or so for about AU$1000 (E7400, xFx 4850), and I think I'm being realistic thinking that I can get about 3-4 years out of it before starting from scratch again.
Reply to The Lady Slayer
I usually buy what was hot 6 - 9 months ago .
Its much cheaper than the top end price you'd pay for the latest releases , and only 6 months ago I was dreaming about being able to afford it .....LOL
And if I had bought it 6 months ago , Id still have it now anyway
I'd take the Ford Focus because insurance on a Ferrari would be high as hell. :)
Nice post though, OP. I agree. I think the main thing to consider though is that this would be good for those who are looking for that best value etc, but for those that have to have the best of the best, they're still going to pay 2 grand for those parts even if it would be better to buy cheaper more often.
------------------------------ This planet will burn good. It has lots of critters on it. Critters burn good...
http://valid.canardpc.com/cache/banner/552078.png
Reply to bonanzaguy
So for Core i7 System What would you recommend the best bang for the buck if next PC upgrade will be 5+ years (Seriously).
Reply to robertomad
A complete rebuild. You might reuse the Case, and possibly the PSU if its high quality. In 5 years the i7 will be in the same spot that Intel's Pentium 4 is right now. Its not going to be worth keeping anything in the system if you want it to be current.
Message quoted 2 times
Message edited by xthekidx on 04-19-2009 at 10:44:55 PM
GTX 260 Core 216
Reply to xthekidx
Thank you xthekidx. Yes you're right. That is what I have currenlty, p4 2.8 and I'm planning to build a new rig but still can't decide between 920 or 965. Or wait for 950 or 975. As you maybe notice I have a lot of forum question about this. I had an eye for 940 before but then I read alot and realized that it's really not worth the money. So now my choice is 920 and 965. Though I must say that I'm not OCing the new rig probably but until 5+ years time I will.
Reply to robertomad
Get the 920, use the money saved to buy a big monitor and some good GPU's. The 965 is definitely not worth the money.
GTX 260 Core 216
Reply to xthekidx
What Graphics would you recommend that has s-video in it. Because currently my pc is connected to my LCD TV and because this is the longest cable I can find at the moment. I was to VGA would be ideal to loose the grainy pixel bit.
Reply to robertomad
- 0 +
I7-920 will probably last longer than we think, particularly if you OC to 965 speeds which is easy and safe.
Plan on a vga card upgrade part way through.
Reply to geofelt
- 0 +
Thanks for the reply,
my idea was really more to find a case, PSU and cooler that you really like. If you like the 300 and the PSU then thats great, but I think you can justify spending more money on those parts if you wanted too and still get a good deal because they will last. Otherwise I would be thinking along the same lines for the CPU, RAM, MOBO and GPU, although if you are buying now there are soon to be better deals out there, as I am sure know these things change very fast.
Cheers for the suggestion mate
Reply to nerrawg
- 0 +
Cheers for the reply,
Agree about there being another side to this of course, This comparison was more for those people who want to save money on their gaming pc's so that maybe some day they can save enough to buy a Ferrari - :D , well something along those lines. It wasn't meant for those that get a stiff one just looking at their BFG GTX 285 or the cpu temp readout on their vapochillLS. Not that I don't like some sweet hardware - just would rather have that Ferrari instead.
Reply to nerrawg
- 0 +
Of course it depends on what you lay in the definition of a midrange system, but in the comparison I chose it actually shows that if you did upgrade more often you would get more back on that meagre student budget of yours (mine as well). Of course you might view the value systems that where suggested here as "mid range" cause they are pretty powerfull - just depends on your perspective of course
Reply to nerrawg
- 0 +
Exactly - you won't be able to able to resell anything - better to do change stuff out more often and then sell the parts - guaranteed to save you lots of money and be better in the long run - however all depends of course if you can be bothered to do this, just remember that building a system only takes a day or to set up properly even if you overclock.
Remember there is a sweet spot though - and that is what this article was all about trying to find - which from what it looks like to be between 500-700 dollars on the right upgrades per year or 2 - this may of course change. Don't know about how this changes over in Oz - I would call the E7400 and a 4850 a value option - but definitely a good choice. If you can get 3-4 years out of it then your gaming demands aren't as high as I was talking about in the comparison - there we were looking at systems that would play all games at near max settings ever year. That is why the upgrading is important. If you don't have this a requirement then of course you don't need to upgrade as often - or for that matter buy an expensive machine in the first place :sol:
Reply to nerrawg
- 0 +
Unless you don't care at all about burning the green stuff, for all sake don't get the 965, or 940 for that matter! :non: Even if you don't overclock the 920, the 940 and 965 don't offer a performance increase near justifying the premium for these more expensive CPUs. Only get the 965 or 940 for bragging rights - and even then it just seems silly to the rest of us because you can overclock the 920 just as high as the 965 - it all depends on how lucky you are with the binning! Unless you are using the PC for professional apps that are incredibly CPU bound do not get these more expensive i7 models:
http://www.neoseeker.com/Articles/ [...] ew/31.html
http://forums.anandtech.com/messag [...] id=2295517
http://forums.overclockers.co.uk/s [...] p=13868287
Reply to nerrawg
- 0 +
I try to avoid the term "future-proof," but I think "future-resistant" is not unreasonable. The only performance upgrade I've done on my rig is the GPU (more than once), but I find it hard to believe that a Q9450 will be anywhere near useless even 3-5 years from now, and I don't see my PSU dying either. My mobo is Abit, so it's a dead-end, but it is a good one for being a P35. I feel the itch to build, but so far I've satisfied it by building for family and friends, and a secondary PC I've taken to thinking of as the "Green Gamer." There's nothing I anticipate running for which my CPU will likely be insufficient, so I'll probably stick with it for the foreseeable future.
Reply to jtt283
- 1 +
I agree with you on the fact that your cpu will not be useless - your entire build will probably be just fine in 3-5 years. There are still people running on P4's as we speak and doing relatively fine with that. I actually think you will be in an even better position in 3-5 years time then they now because it will probably take that 3-5 years before any apps or games have 4 cores as a requirement, and I cannot imagine 6 cores or more being a requirement until much later.
To put that into the perspective of this comparison, the 3 year old 2007 enthusiast build in this example still plays the newest games - including crysis at very respectable settings for its age and even newer PCs. The idea behind the article was more to focus on how much you should pay. It shows that while that 2007 enthusiast system still is pretty awesome - you had to pay a hefty premium to get it and you could have saved around $1000 just by buying value systems (probably more if I had taken into account that those value systems could well have been upgraded instead of completely replaced). So I did not intend to say that buying an enthusiast or mid range system is wrong - far from it, I just intended to discover with this comparison what the best bang for your buck would be. Also the goal of this comparison was to always have a system that would play games at the best settings at the common resolution of its time (not many people had 1920 x 1200 or 2560 x 1600 in 2007). Thank you for the response though, and it gives this article important balance because as you stated you can keep a pc for 3-5 years. I just think that if you expect it to play the newest games at the highest settings 3-5 years from now you will at least have to upgrade the GPU
Message edited by nerrawg on 04-30-2009 at 01:58:59 PM
Reply to nerrawg
should we define mid-range first? it seems to be a bit more debatable now because of the economic state and whatnot.
IMO about $1200 is a mid range build because thats around what most of us on here are ready to pay for a new build.
But yes pc's can be future resistant, to a point though, as soon as the next socket comes out then you lose your CPU, mobo and most of the time memory, and if you've had your PSU and gfx card for a year or more then you'll need to upgrade that too if you want to stay at a decent fps with good quality frames.
Reply to Helloworld_98
- 0 +
What is the best bang-for-the-buck GAMER solution that will save you the most money in the future?
Continuing in the spirit of the comparison that started this thread I would like to do an experiment to find out what the best bang-for-the-buck system solutions are that you could by as of May 2009. Of course this will have to take into account their future performance - so it will be impossible to tell now what is the best one. This experiment will therefore continue until 2010-2011 to determine which of the system builds that seemed good now were actually the best in terms of dollars spent and playability. The systems may be completely upgraded in the future - the only winning factor here is the lowest total cost overall throughout the next 2-3 years.
These system builds will only consider CPU, GPU, MOBO and RAM - for the sake of simplicity as these are the components that change the most in terms of gaming performance.
Requirement for these systems (in May 2009) is that they play all games at 30 fps or above on high setting at 1920 x 1200 res. The requirements may change in time (meaning that some systems might have to be upgraded when this happens)
Prices will be taken from Newegg, mail-in-rebates included
May 2009 systems (All games at high settings on 1920 x 1200 resolution) Prices:
Value system(DDR2):
CPU: AMD Phenom II X3 720 Deneb 2.8GHz $140
http://www.newegg.com/Product/Prod [...] k=720%20X3
GPU: MSI R4830-T2D512 Radeon HD 4830 512MB $77
http://www.newegg.com/Product/Prod [...] 6814127420
HIS Hightech H483FN512P Radeon HD 4830 512MB $77
http://www.newegg.com/Product/Prod [...] 6814161260
MOBO:BIOSTAR TFORCE TA790GX 128M AM2+/AM2 AMD 790GX $95
http://www.newegg.com/Product/Prod [...] 6813138130
RAM:OCZ Blade Series 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) $30
http://www.newegg.com/Product/Prod [...] 6820227420
Total System Cost = $420
Value System Core i7 (DDR3 - future upgradable?)
CPU: Intel Core i7 920 Nehalem 2.66GHz $280
http://www.newegg.com/Product/Prod [...] 6819115202
GPU: HIS Hightech H487FN1GP Radeon HD 4870 1GB 256-bit GDDR5 $170
http://www.newegg.com/Product/Prod [...] 6814161269
MOBO: ASUS P6T LGA 1366 Intel X58 ATX Intel Motherboard
RAM: Crucial 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333
MOBO and RAM combo $267
http://www.newegg.com/Product/Comb [...] mbo.186559
Total System Cost = $717
Mid-Range system (DDR2):
CPU:AMD Phenom II X4 940 Deneb 3.0GHz
MOBO: GIGABYTE GA-MA790X-UD4P AM3/AM2+/AM2 AMD 790X
CPU and MOBO combo: $294
http://www.newegg.com/Product/Comb [...] mbo.182237
GPU: 2 x SAPPHIRE 100245HDMI Radeon HD 4850 512MB 100 + 120 = $220
http://www.newegg.com/Product/Prod [...] 6814102824
RAM: G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) $50
http://www.newegg.com/Product/Prod [...] 6820231145
Total System Cost: $564
Mid-Range system (DDR3 - future upgradable?):
CPU: AMD Phenom II X4 955 Black Edition Deneb 3.2GHz
MOBO: GIGABYTE GA-MA790FXT-UD5P AM3 DDR3 AMD 790FX ATX
CPU and MOBO combo: 245 + 180 - 30 = $394
http://www.newegg.com/Product/Prod [...] 6813128377
GPU: XFX HD-489A-ZDEC Radeon HD 4890 Xtreme 1GB 256-bit GDDR $230
http://www.newegg.com/Product/Prod [...] 6814150360
RAM: Patriot Viper 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 $90
http://www.newegg.com/Product/Prod [...] 6820220331
Total System Cost: $714
Enthusiast System (DRR3 - future upgradable?):
GPU: EVGA 896-P3-1170-AR GeForce GTX 275 896MB 448-bit DDR3
CPU and GPU combo: 280 + 250 -20 = $510
http://www.newegg.com/Product/Comb [...] mbo.187411
2nd GPU: EVGA 896-P3-1170-AR GeForce GTX 275 896MB 448-bit DDR3 $250
http://www.newegg.com/Product/Prod [...] 6814130475
MOBO: EVGA 132-BL-E758-A1 LGA 1366 Intel X58 $290
http://www.newegg.com/Product/Prod [...] 6813188039
RAM:CORSAIR DOMINATOR 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1866 $250
http://www.newegg.com/Product/Prod [...] 6820145232
Total System Cost: $1300
Ok this is now the first draft.. what do you guys think?
Message edited by nerrawg on 05-01-2009 at 12:43:10 AM
Reply to nerrawg
I don't know if I would put the PII 955 in the mid-range system, its seems more high/mid-high end especially for the price tag. I would think more along the lines of a PII 720 in the midrange, and value/budget system E5200 or maybe E7400.
GTX 260 Core 216
Reply to xthekidx
- 0 +
Yeah I was considering that too - but I don't know if the E5200 system will be good enough at 1920 x 1200 res without spending relatively more on the videocard - as high settings in all games at 1920 x 1200 is the requirement of the comparison. Also because I think I can build an AMD system with the PII 720 at about the same price of a E7400 + P45 build (need CF for cost effective performance at 1920 x 1200 i think). However I can't really be certain of this until Newegg starts to work again.
My idea was this:
value: PII 720 DDR2 system at max cost $400-450 (likely 4830 or 4770 CF - 4890 is too expensive I think)
Midrange: 955 DDR3 system at max cost $800
Enthusiast: Core i7 920 DDR3 system at no max cost - just good choices of video cards and mobo for performance (i.e. no point on wasting excessive amounts money really so I assume this will be around $1200 - maybe more if there is good reason for it.)
What do you think about these ideas, and how would you build the systems?
Message edited by nerrawg on 04-30-2009 at 03:00:46 PM
Reply to nerrawg
Well that is sound reasoning I guess, but I don't think that a budget/value system would likely be coupled with a 24" monitor, more like a 19-22" and not likely to be gaming at 19x12 res.
I do think though that Phenom II definitely owns the midrange build segment of the market, and quite possibly the value end too. Enthusiast definitely belongs to the i7. I think at $190 the PII 940 is the best choice for a midrange processor, $250 for the 955 seems too steep IMO, especially when you look at the price difference of AM2+ to AM3 with the 955, its like $100 if you go with that instead.
Message edited by xthekidx on 04-30-2009 at 03:34:53 PM
GTX 260 Core 216
Reply to xthekidx
- 0 +
Agree about the price premium on DDR3 not being worth it really - but that is what I want to find out if the same is true in the long run and if saving those $100 and losing what may be an upgradable AM3 motherboard is worth it in the long run. I think it will be - but this experiment is meant to determine for sure if I am right or not. I might have two mid range builds- one with the 940 and one with the 955 - also one of those using 4850 CF and the other on a 4890 1 GB (for potential upgrade in future to a 4890 CF) - what do you think? I hope that would cover the bases for a future analysis on whether we were right or wrong about upgrading to DDR3 now or later - and the other components as well
Also you're right that the value system isn't really a budget-end cheap system, but that's not really what I intended it to be.
It is meant to be the cheapest reasonable solution to fulfill the requirements.
The mid-range system is supposed to fulfill the requirements, and then some, in a kind of "spirit" of predicting that it will last and be upgradable (like people in the forum argue), and the enthusiast system is meant to excel as far beyond the requirements as is reasonable to do with today's technology (with the bragging rights that an enthusiast needs for his ego).
However I understand that this might be confusing - sorry bout that.
Message edited by nerrawg on 04-30-2009 at 03:54:32 PM
Reply to nerrawg
- 0 +
Ok finished the first draft on the 2009 systems - what do you guys think?
Reply to nerrawg
Looks pretty good, although a lot of people would opt to not get a dual GPU setup if it could be helped right off the bat if it can be helped, since it occupies all the slots and you don't have the option of upgrading by just adding another later. Also, this requires a better motherboard and power supply than if you just planned on going with one GPU, so the cost of this kind of setup is not always the best option for bang/buck, especially when playing games that do not scale multi-gpu setups well.
GTX 260 Core 216
Reply to xthekidx
- 0 +
Yep, have to agree with that too kid - but that's also exactly why I included it - the idea was to have one midrange build that is upgradable (DDR3 and 4890) and one that is not (DDR2 and 4850). This way I can see in the future which one actually was the best bang for the buck. As for the value system I can't really see how to get enough power without CF, if you have any ideas please help. Thanks for the responses mate!
Reply to nerrawg
IMHO a 4890 doesn't worth the 250 bucks you have to pay for it before rebates when you can get a 4870 1 GB for 190 and have almost (90-95%) the same performance, also, X58 mobo are now under 200, so you can put a core i7, an X58 mobo, 3GB ddr3 tri channel memory and a 4870 for about $700, then later 6-12 months later a second 4870, another 3GB of memory (that by the time should be like another $200) and you'll have a very solid rig for at least another 12 months. Maybe you can even invest another $50 for better colling solution and go OC your CPU.
In short, I think is a better idea to build for upgradeability for the mid term (to build a machine that you can upgrade a year or so after and then keep it for another 1-2 years after a serious upgrade), IMO you'll end up with a more powerful system than if you build from the scratch every year.
Reply to winterblade
- 0 +
Ok well I will add a "cheap" core i7 system into this comparison as well and we will see how it all turns out 1, 2 and 3 years down the road.
Personally I don't think that it will be the best, I think the phenom PII 720 solution is the best bang for buck and will be in the future - when upgraded to a core i5 and next gen gpu in 1-2 years time. But the whole point of this is to see if that is right - and you make a good point for adding a bare budget core i7.
Reply to nerrawg
- 0 +
Ok, just been thinking and I think this experiment future post needs its own thread so I will be moving it
Reply to nerrawg
- 0 +
I agree with Winterblade. Some upgradability is needed, and adding a second card is certainly a viable option. My system illustrates how lacking that can hurt. I'm pretty much limited to single cards, as the second PCIE slot on my system would run at X4. Even so, for the games I play, and at 1680x1050, it has a lot of life left in it.
I usually start out at the "value" end, then upgrade into the mid to enthusiast range; time will ultimately drop it into the "value" range again. My current system started with "only" a 7900GS, which was a great card, but utterly below the radar today. Then it got a 3850, again a card that is now bare minimum (equivalent to a 4670). Now it has a 4850, which is no better than mid-range, even though it is overkill for my games. I've reached a point where I don't foresee a better single card helping a whole lot. If I need more, chances are I'll need Crossfire, which means a new mobo, but I'll probably keep my CPU and RAM. My PSU I hope to still be using in ten years, as I don't want to need a 1kW PSU just to play games.
Reply to jtt283
- 0 +
nice!
like how you brought up this topic! :o
i go with the value rigs..
if you go for the phenom 2 720.. i say you pair it with at least a 4770 :D
Reply to binwhui
- 0 +
I also think this has been an interesting thread.
It might be worthwhile to consider the cost of bringing a system that was at each of the levels 5-6 YEARS ago up to snuff to make current games playable, say at 1680x1050 on med-high settings, or 1920x1200 with medium settings. I'd call a game "playable" if you can maintain 30-35FPS. Then add that machine's original cost to the upgrade costs for a total. It would probably be fair to exclude an anomaly like Crysis.
Reply to jtt283
Well playable is 24fps+ in my opinion, otherwise no one would buy Gaming consoles.
Message edited by Helloworld_98 on 05-02-2009 at 04:29:28 PM
I like this thread, especially the debunk of the whole "future proof" BS.
I think this should be a sticky or have it linked to the part choosing thread.
Reply to dragoon190
- 0 +
Yeah, I only use the term "future-resistant,: typically referring to a build that can be upgraded.
Reply to jtt283
- 0 +
Edited some of the evaluation and added a graph, its a bit more fancy now - what do you guys think?
Reply to nerrawg
- 0 +
I think the graph is somewhat arbitrary; I see no data to support it, and in fact I think it would look very different, as at the high end, more and more money can easily be spent for only small gains in performance.
The next mobo I buy, however, will likely have two PCIE slots on it, if only to allow for the remote possibility that I might someday want two GPUs in SLI or Crossfire.
Reply to jtt283
- 0 +
Um - the graph is supposed to show exactly what you said - either I can't draw graphs or you can't read them correctly, but if you look at it the slope increases steeper after the sweet spot indicating more money needs to be spent per unit of performance. I will add units and make a few more with the data from the comparison when I can be bothered
Message edited by nerrawg on 05-03-2009 at 04:11:21 AM
Reply to nerrawg
I think the graph makes a pretty good representation of the situation, but real numbers would make it a stronger argument...that might get complicated deciding what units to measure performance in though.
GTX 260 Core 216
Reply to xthekidx
There are 775 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 raulkm won the Uniformed badge
  • 01:00 letus won the Uniformed badge
  • 01:00 pmiddy won the Uniformed badge
  • 01:00 MarcieMark won the Uniformed badge
  • 01:00 kaypeezee won the Uniformed badge
  • 04:06 xyz001 won the Sophmore badge
  • 01:00 scione won the Freshman badge
  • 01:32 aford10 won the Home Brew badge
  • 01:00 Kevinator won the Uniformed badge
  • 01:00 adis won the Uniformed badge
