Help
deans_girl16
I just purchased a Toshiba Satellite® C655D-S5048 Laptop and used Apricorn Drivewire to try transfering the data from the hard drive in my old laptop to the new laptop. Now when i turn on my new laptop it won't boot up and says that there is no bootable device. How do I repair this problem??
answer
Last reply
More about help
Err, I can't remember this too well but before each windows OS spot on a hard drive it tells the computer that that's where the OS is so it can boot from it. I don't know about the software you used, but you probably transfered just all the files from one hard drive to the other, ignoring that spot on the original hard drive that says that's where it should go to when the computer boots up and looks for an OS to use.. ... so... Your new hard drive doesn't tell your computer that there is an OS on it so that's why you're getting that message.
I don't know how to solve this, but I think this is the cause of your problem.
Hard Drives
Laptops
Toshiba
Storage
Related Resources
- Need help picking out a new laptop hard drive.
- HELP! Laptop Repair
- Help! Laptop Wont boot.
- Laptop
- No bootable device error Toshiba Laptop HELP!!!!
- Old laptop
- Apricorn Aegis Mini 60 GB
- Toshiba A665 Laptop Wont boot
- How to repair a laptop cd drive
- Apricorn sata wire usb device driver not found
- Help with a new used laptop
- Looking for a $1500 laptop for college.
- Problem with Toshiba Laptop
- Hard Drive Replacement For Toshiba C650d
- Can a hard drive from an hp laptop fit into a toshiba laptop
- Hard drive is not recognized by my laptop
- Laptop Hard Drive Not Recognized by USB
- Will Toshiba replace my 2.5" hard drive? Laptop bought in December '11
- Laptop Will Not Boot - Drive Shows No Problems in Repair
- Boot laptop drive clone on desktop
