Tom's Hardware > Forum > CPU & Components > CPUs > CPU Heat Problem
CPU Heat Problem
Forum CPU & Components : CPUs - CPU Heat Problem
Hey i have been trying to fix this for the past couple of days now and am really stumped. I have a laptop that had a heating issue i replaced all the parts except for the processor and its does not even get hot but the processor thinks it is i checked the temperature and its no where near the safety limit. Is the a way to reset the processor so it stops thinking its overheating?
Sponsored Links
What are the specs of the laptop?
Reply to AKM880
- 0 +
AMD Turion 64 X2 TL-62 2.10Ghz
4Gb Ram
320GB Hard Drive
Reply to anf
- 0 +
Well, if it runs fine, then it doesnt matter what it thinks haha. If it doesn't affect the performance or stability, then don't worry about it.
------------------------------ AMD Phenom X3 8450|eVGA nForce 730a|eVGA GTX 260 SC| Corsair DDR2800 2GBx2|Acer19" and HP 21" Dual| n52te Gamerpad
Reply to JDV28
- 0 +
+1 .... lol i second that!!!!!!
Message edited by OvrClkr on 07-24-2009 at 08:57:27 AM
------------------------------ 550 @ 4.0 Ghz 1.425v
BFG GTX 260 (216)
4GB G.Skill @ 960MHz
Thermaltake TP 850w
Reply to OvrClkr
broken sensors are not uncommon.
Reply to neon neophyte
There are 1156 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
